oem power doors
eclipse00gt
Member - Posts: 8
Posted: October 14, 2009 at 10:59 PM / IP Logged
First of all, hello fellow electrical gurus. A little background info, I have 2000 astro van all manual, and one door was bent. So I bought the doors of a 2003 astro van which was all power. Now my question is how can I, if its possible at all, connect the power locks, power window, and the power mirrors to make them work?
The doors came with all switches and I have some wire slack from the door.
t&t tech
Platinum - Posts: 2,622
Posted: October 15, 2009 at 7:03 AM / IP Logged
here's a little wiring diagram, the locks are said to be positive trigger from factory, but i assume you would be using two relays for this, you can wire it for negative trigger! It won't make a difference!
t&t tech
Posted: October 15, 2009 at 7:05 AM / IP Logged
oem power doors -- posted image.
t&t tech
Posted: October 15, 2009 at 7:06 AM / IP Logged
The output terminals of the switch will be conecting to pin 86 of the left relay and pin 85 of the right relay!
eclipse00gt
Member - Posts: 8
Posted: October 17, 2009 at 1:05 AM / IP Logged
got it! thanks for the replies! Now could that work for the windows as well?
Platinum - Posts: 13,725
Posted: October 17, 2009 at 1:54 AM / IP Logged
Yes the same type of relay setup will work for the windows.
