08 4 runner
1caraudioman
Member - Posts: 33
Posted: October 17, 2009 at 2:42 PM / IP Logged
anyone done the back window off a after market alarm? if so how??
Platinum - Posts: 13,725
Posted: October 17, 2009 at 9:31 PM / IP Logged
If the vehicle has a light on the dash that tells you the glass is open, it should be pretty easy.  You will have to figure out where the switch is located.  Chances are it will be in the latch that the glass locks into.  There should not be that many wires going into the door.  Using an Ohm meter, check the resistance from each wire in the harness to ground.  With the window open or unlatched, it should be a very low resistance.  Close the glass and it should read very high resistance.
Chris Luongo
Platinum - Posts: 3,746
Posted: October 17, 2009 at 9:37 PM / IP Logged
Been covered here many times, both on the 4Runner and Sequoia....search feature should find it.
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
