gmdlbp interface
rksterling
Member - Posts: 46
Posted: November 28, 2009 at 11:49 PM / IP Logged
I am trying to wire a interface module - gmdlbp with a two way autostart  AS-2361-TW installed in a 2004 chev silverado
On Bypass module gmdlbp I need to know where to connect these wires.  The first three are shown to go the the starter, but I am not sure where.
Green (-) = Lock Input
Blue (-) = unlock Input
Violet/White = Connected to disarm wire from remote starter if oem alarm sounds
Orange (-) = Panic Input
Any help would be appreciatted,
Thanks in advance!
sparkie
Platinum - Posts: 2,061
Posted: November 29, 2009 at 7:35 PM / IP Logged
Connect the Green wire from the bypass to the Brown wire in the 12 pin harness, the Blue bypass wire to the Green wire in the 12 pin harness, the Brown bypass wire to the White wire in the the 12 pin harness, the Red bypass wire to a fused battery source and the Black bypass wire to ground. You can use the Orange wire for Panic activation if you want. If desired, connect it to the Blue wire in the 12 pin harness. This is usually for the trunk release, but you can then use the remote's trunk button as a panic button. The PURPLE / White won't be needed.
sparky
