astrostart 2504 2000 chev blazer no crank
Steveo_supremo
Member - Posts: 34
Posted: December 15, 2009 at 12:11 PM / IP Logged
Put  a Astrostart 2504 into a 2000 Chevy Blazer yesterday. The remote starter will not crank the vehicle. It does not power up the starter wire (P4-5 blu wire on unit). I can start the engine with the key and then take over the vehicle with  the remote start no problem, it just won't crank the starter. I have checked and triple checked my connections and can't find anything wrong. Do I have a bad brain or is it a programming issue that I have overlooked?
FWIW I used a PLJX bypass module but I know it's not a passlock issue because the starter wire never gets pwered up at all by the remote start, also if it was a passlock issue this vehicle would start and die.
monty_77
Copper - Posts: 491
Posted: December 15, 2009 at 1:51 PM / IP Logged
if you hooked up the anti-grind of the r/s make sure that the light blue is on the key side and the the dark blue it on the starter side of the wire if hooked the other way it will not start the vehicle.
easy way to check that would be to jump the two cut starter wires together and try to rs it then
Steveo_supremo
Member - Posts: 34
Posted: December 16, 2009 at 3:51 PM / IP Logged
Fixed it with a new brain.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
