455j and 555c
Lubrano
Copper - Posts: 113
Posted: December 19, 2009 at 6:00 PM / IP Logged
I have two question installing these modules in a 199 jeep grand.  The 4555j has a blue-black wire (input from remote start)  I want to hook it up to H2/4 GREEN/ black (factory disarm ) on the dei brain?
Second on the 555C it needs a (-) signal to power it up.  I have many (-) on the brain which one to use? I have (-) status output, (-) accessory relay trigger, (-) starter relay trigger, (-) ing relay trigger, (-) factory disarm, probally others I missed when reading as well.
The unit is a 591xv.
Thank you
Mike M2
Platinum - Posts: 2,652
Posted: December 19, 2009 at 6:58 PM / IP Logged
You need to connect the blue negative wire from the 555C and the blue/black wire from the 455J and connect both to the blue status wire on the 591. No diodes needed, simply connect all 3 together.
Mike M2
Tech Manager
CS Dealer Services
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
