2009 vw rabbit bypass?
shadowinfector
Copper - Posts: 199
Posted: December 22, 2009 at 11:17 AM / IP Logged
anyone know which bypass kit i can use for the immobilizer? i am not sure if i can use 556uw or 556u, I am also planning on using the cansl2... any info in this vehicle, i have a potential customer bringing the car to me in the next couple of days. Any help would be greatly appreciated. Thank You
zerepdivad
Silver - Posts: 605
Posted: December 22, 2009 at 1:41 PM / IP Logged
556u is where it's at on that vehicle for immobilizer.
A DMM is a beautiful thing.
shadowinfector
Copper - Posts: 199
Posted: December 22, 2009 at 6:36 PM / IP Logged
thanks....has anyone worked on this vehicle? is the wiring diagram the same as the 2007??? thanks
05gt
Silver - Posts: 628
Posted: December 22, 2009 at 11:20 PM / IP Logged
you need to use the 556U from DEI for the immobilizer bypass, and you will need to use a piece from Idatalink if you want to avoid some headaches
idatalinks volkswagen platforms are almost bulletproof and are most of the time are 2 wire hookup, well in your case it will be 3 wires
Moderator - Posts: 12,488
Posted: December 23, 2009 at 6:42 AM / IP Logged
Same as the 07's
shadowinfector
Copper - Posts: 199
Posted: December 23, 2009 at 3:43 PM / IP Logged
thanks, I could also use the can-sl2 from fortin correct?
shadowinfector
Copper - Posts: 199
Posted: December 23, 2009 at 3:44 PM / IP Logged
2009 VW Rabbit
tedmond
Gold - Posts: 4,610
Posted: December 23, 2009 at 4:52 PM / IP Logged
go to www.ifar.ca, select your car and you will find out. sorry shadow infector, but not all info can be spoon fed to ya.
shadowinfector
Copper - Posts: 199
Posted: December 24, 2009 at 6:03 PM / IP Logged
hahaha, damn you dont have to be harsh i just wanted to see if any other installer has used done this car with that module and if they had any problems
nade2175
Posted: January 17, 2010 at 11:41 PM / IP Logged
go to viper.com click interface module and then type your car year and model it tells you what module you need, hope this will help...
viper arm
Friday, January 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
