ignition 2 wire
ford man
Member - Posts: 7
Posted: December 29, 2009 at 1:30 PM / IP Logged
I have 2005 Mercury Sable. I want to install a Design Tech Remote Starter. Model # 20092. I have a question about the Ignition 2 wire on this model of remote starter. This wire shows a negative so I will have to add a relay, but my question is cant you just run another wire off of the ignition 1 wire on the remote starter to the second ignition wire on the vehicle. Also this is an older model starter does it need to be initialized before the first use. Thanks for your help.
t&t tech
Platinum - Posts: 2,622
Posted: December 29, 2009 at 3:09 PM / IP Logged
No you cannot! all wires, once from oem specs are part of a seperate circuit, they must remain that way!
ford man
Member - Posts: 7
Posted: December 29, 2009 at 3:17 PM / IP Logged
Ok I will hook up a relay to the second ignition wire negative.  I need to hook up a relay to make this wire positive right? Do you know if this unit needs to be initialized. Thanks for the quick response.
tommy...
Gold - Posts: 1,901
Posted: December 29, 2009 at 3:43 PM / IP Logged
ignition 2 wire -- posted image. Convert a Negative Output to a Positive Output
If you have a switch or an alarm or keyless entry that has a negative output that you wish to use to switch a device that requires 12V+ such as a horn, dome light, parking lights, head lights, hatch release, etc., wire a relay as shown below to convert the negative output (trigger) to a positive output.
Here's the same configuration showing a negative output from an alarm or remote keyless entry used to activate a trunk release solenoid that requires 12V+ to release the trunk.
Most units require some sort of "initializing"... Is that the candy-bar , rectangle looking unit...Or more square...?
M.E.C.P & First-Class
ford man
Member - Posts: 7
Posted: December 29, 2009 at 3:51 PM / IP Logged
The unit is more square. I was reading up on some of the newer ones and it says they need to be initialized. It does not have valet switch, and is starter and alarm combo.
jrilla
Gold - Posts: 1,498
Posted: December 29, 2009 at 8:23 PM / IP Logged
The last design tech I did 10 years ago was initially programmed so you had to flip the switch each time you wanted to remote start, but it was programmable so you just needed to program it so it wouldn't do this. That is funny because I was thinking about how stupid that was to have that as a default option and pretty much useless as a feature altogether.
ford man
Member - Posts: 7
Posted: December 30, 2009 at 8:34 AM / IP Logged
Yes I noticed some of the units have an on and off switch, but this one doesn't unless they consider the hood pin switch the on and off. I think I have all the information I need. Just need to hook it up now and see what problems arise......hopefully none. Thanks again for everyones help.
tommy...
Gold - Posts: 1,901
Posted: December 30, 2009 at 8:53 AM / IP Logged
Or just put a slightly better,more reliable unit in there...Those things were junk...! At least they use to be...!
ford man
Member - Posts: 7
Posted: December 30, 2009 at 9:00 AM / IP Logged
i have had good luck with junk so far. Ive put in alot of Bulldogs because people want cheap ones. I ve heard this Design Tech is junk too, but I ve heard that about Bulldogs also.No problems yet. Knock on wood.
