viper 5901 park lights
nrose
Member - Posts: 19
Posted: February 14, 2010 at 10:38 AM / IP Logged
Hey I installed a Viper 5901 on my 2006 GMC Sierra some time ago.  Everything functions perfectly, however, it does something weird with the park lights that I can not seem to figure out.  When the truck is started, the park lights come on....after a random amount of time (usually 6-10 minutes into start) the park lights shut off.  They turn back on if you unlock the doors, or anything else.
Anyone have any ideas???
nrose
Member - Posts: 19
Posted: February 15, 2010 at 1:05 PM / IP Logged
anybody ever seen this before?  is it normal maybe?
kgerry
Platinum - Posts: 3,455
Posted: February 16, 2010 at 11:42 AM / IP Logged
where did you grab park lights?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
nrose
Member - Posts: 19
Posted: February 16, 2010 at 2:26 PM / IP Logged
Hey Kevin, I used a Fortin INT-SL+ and used the park light wire on that module.  Maybe I should check to see where the signal is actually dying for the park lights??  If the Viper still has output for the park lights then maybe I should bypass the module and go directly to the park light switch?
Thanks a million for any information!!
kgerry
Posted: February 16, 2010 at 4:42 PM / IP Logged
use the Viper straight to the Park light wire at the BCM (-)... super easy to get to and i've never had any issues with using it.... might be the module flaking out on you.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
tedmond
Gold - Posts: 4,610
Posted: February 16, 2010 at 4:54 PM / IP Logged
run a wire for parklights to the vehicle. dont use it through the INT-SL. I use lots of fortin products, the only thing i dont use via the INT-SL is parking lights. There were some problesm with the INT-SL if it didnt haev the latest firmware on it. It was because the unit didnt receive a high current ground when running (status wire). although this was a electrical issue, the software issue is sometimes the resistance would fluctuate so it would throw off the parking lights.
Ted
Compustar Expert
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
