viper 5901 2006 accord dlpk
p-wi
Posted: February 17, 2010 at 8:19 AM / IP Logged
so im just starting this install and wanted to make sure i understood all the connections. as i laid out all the wires and looked at the installation instructions i instantly became overwhelmed and now need serious mental help.
bit of background i understand diodes, have hooked up relays, one remote start/alarm install previous.
so: exactly what wires do i need from the ignition switch harness?
also im on a bit of a time restraint so to make it easy can a knowledgeable person look at my instructions and tell me hook this wire to that and this to that and now your done?
thanks in adavance!
dman007
Copper - Posts: 106
Posted: February 17, 2010 at 9:58 AM / IP Logged
From the ignition harness, you will need
12volt constant - WHITE
Ignition 1 - BLACK / YELLOW
Ignition 2 - BLACK/ RED
Accessory - BLACK/ RED
Starter - BLACK/ WHITE
Remember all of these wires will be heavier gauge, coming directly from key clyinder wiring harness.
DTS Performance
St Petersburg, FL
p-wi
Posted: February 17, 2010 at 10:25 AM / IP Logged
what wires do those hook up to on the 5901 harness
x1le
Copper - Posts: 171
Posted: February 17, 2010 at 10:47 AM / IP Logged
12volt constant - WHITE _ connect to red, redwhite, and redblack
Ignition 1 - BLACK / YELLOW _ connect to pink
Ignition 2 - BLACK/ RED _ connect to pink/white
Accessory - BLACK/ RED _ connect to orange
Starter - BLACK/ WHITE _ cut wire in half and connect the car side to purple and the key side to green
don't forget to verify wire color accuracy with a meter prior to connecting.
dasbogie
Silver - Posts: 514
Posted: February 17, 2010 at 10:54 AM / IP Logged
Do you have  ac bypass for the transponder?  the dlpk does door locks, factory alarm disarm, trunk pop, triggers but not the chipped key
p-wi
Posted: February 17, 2010 at 11:14 AM / IP Logged
i was told that the dlpk had a immobilizer bypass and it connected directly to the 5901 just needed 2 additional wires.
is the accessory supposed to be WHITE/ RED_ORANGE????
p-wi
Posted: February 18, 2010 at 5:42 PM / IP Logged
does anyone know where the orange on the 5901 connects to? white and red?
dasbogie
Silver - Posts: 514
Posted: February 18, 2010 at 8:37 PM / IP Logged
did you test that wire with a meter in all key positions?
p-wi
Posted: February 18, 2010 at 8:41 PM / IP Logged
what am i testing for volts i assume but what indication in each position, and what is the orange wire supposed to be connection to ?
x1le
Copper - Posts: 171
Posted: February 18, 2010 at 8:43 PM / IP Logged
viper 5901 2006 accord dlpk -- posted image.
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
