cant get into programming c3 rs665
azboy
Posted: February 18, 2010 at 2:16 PM / IP Logged
I just installed an autopage c3-rs665 into my 98 silverado. I cannot get remote start to function because I cannot get into the programming function no matter what I try. I am very mechanically inclined and have installed alarms before so I know the alarm is installed properly"I hope". All I get when I try to enter programming after on off 3 times then pressing the button 9 times is one chirp and thats it no matter what. The led is constantly blinking 4 times when the alarm is off which is puzzling me as well. I have the safety switch grounded and everything else done properly I think and this is not a very advanced vehicle so I just cant figure out where my problem lies and any help would be greatly appreciated thanks....
azboy
calijtee1
Copper - Posts: 121
Posted: February 18, 2010 at 10:05 PM / IP Logged
do you have the hood pin open by any chance  you need to have it open in order for it to go to programming and the autopages are a lil trickier thsan most alarms i also once in a while i have a run in with these auto pages .
installers do it best. we got the magic hands!
azboy
Posted: February 23, 2010 at 9:37 AM / IP Logged
well figured the issue out finally....
I had used those connectors that you crimp to wires to connect them instead of using solder...big mistake obviously so I had went wire to wire re-doing each wire securely soldering each one and after doing this my problem was solved and everything functioned properly...One of the wires or more must have not gotten a good connection from the connectors that I had used but all is good now...so if ur having issues make sure everything is soldered securely
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
