clifford 50.7x 02 subaru wrx turbotimer
Importdude
Copper - Posts: 55
Posted: March 01, 2010 at 8:37 PM / IP Logged
Turbotimer setting is @ 1min.
IT will not stop at 1min tho.
Everything esle works as spose to
2002 subaru wrx
clifford 50.7x
thanks in advance
TONY
Main harness
H1/2 red 12VDC constant input---> battery +12V
H1/3 brown siren output---->siren (+), siren (-) to ground
H1/5 black chassis ground---->ground
H1/7 blue trunk pin/instant trigger input--->yellow/red(keyless module)
H1/8 green (-)door trigger input--->door trigger wire >yellow (intergreted unit)
H1/9 BLACK/ white (-)Dome light----->yellow (intergreted unit)
H1/10 WHITE/ blue remote/start/turbo timer activate input--->E-brake combined with NSS from clifford
H1/11 white parking light output--->parking light wire> orange
H1/12 orange ground when armed---> orange wire from 530T
Door lock 3-pin connector
1 blue (-)500mA unlock output--->(-)door unlock > yellow/red (keyless module)
2 empty
3 green (-)500mA lock output--->(-)door lock > RED / white(keyless module)
Aux harness
H2/2 WHITE/ violet Aux 1 - White wire from 530T
Remote Start input harness
H2/1BLACK/ white (-)neutral safety input--->e-brake wire > EBRAKE PINK Combined with WHITE/ blue remotestart/turbotimer activation wire
H2/2violet/white tachometer input--->Yellow pin 24 @ ecu
H2/3 brown (+)brake shutdown input--->break pedal wire > WHITE/ black @ pedal switch
H2/4 gray (-)hood pin input-->hood pin
H2/5 blue/white (-)rear defrogger -->red @ intergreted unit
Remote Start Aux output
Blue- (-)200ma Status output ----> clutch switch wire GREEN/ YELLOW
remote start connector
H3/1 pink (+)ignition input/output--->ignition wire > Black
H3/2 RED / white (87)flex relay input--->+12V > BLACK/ white
H3/3 orange (+)accessory output--->accessory wire > BLACK/ blue
H3/4 violet (+)starter output--->starter wire car side >BLACK / YELLOW
H3/5 green (+)start output--->start wire key side >BLACK / YELLOW
H3/6 red ignition 1 input--->12V >BLACK/ white
H3/9 RED / black accessory/starter relay input--->12V > BLACK/ white
t&t tech
Platinum - Posts: 2,622
Posted: March 02, 2010 at 5:13 AM / IP Logged
What duration do you have the timer programmed to? Also disconnect that WHITE/ blue wire from the H1 harness that is connected to the nss and the ebrake! It's only an external trigger source for the R/S portion!
Importdude
Copper - Posts: 55
Posted: March 02, 2010 at 1:47 PM / IP Logged
depin'd
also turbotimer works
i was pressing the wrong buttons
what i thought was turbo timer was remotestart and it kept the car on
for the 50.7 its function function remotestart to turbo timer mode
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
