temporarily disconnection remote start
bprusty33
Posted: April 16, 2010 at 12:11 PM / IP Logged
Currently have a remote start on my suv and I need to temporarily disable the remote start.  I lost my only set of keys and am having a locksmith come out to originate and program 2 keys for me and they stated that if I had a remote starter on the car to disable it.  Can I just put my remote start in valet mode or turn the toggle switch off or do I need to disconnect the ground wire?  Your help will greatly be appreicated.  Thanks.
Mark Mizenko
Copper - Posts: 460
Posted: April 16, 2010 at 1:19 PM / IP Logged
Dont just disconnect the ground wire for the remote start, that could cause problems.  Or do you mean the Negative terminal on the battery?  That would be ok,  Just becareful reconnecting it, the vehicle may try to remote start then.    There may be a hood pin switch connected to detect the hood open, and not remote start.  Or the toggle switch inside the vehicle may disable the remote start.  Switch it OFF.
icearrow6
Copper - Posts: 497
Posted: April 16, 2010 at 7:49 PM / IP Logged
if you can please post alarm model # that way we can see if the switch will disable remote start. otherwise most alarm systems have a "neutral safety" (-) negative input. If you disrupt this wire it will definitely disable the remote start.
bprusty33
Posted: April 19, 2010 at 1:23 PM / IP Logged
its the clifford matrix alarm/remote start unit model number rsx3.5.......thanks :)
KPierson
Platinum - Posts: 3,527
Posted: April 19, 2010 at 2:08 PM / IP Logged
Take it back to the installer and ask them where the NSS is located.  If they didn't mount it where you can get to it have them move it for you.
Kevin Pierson
elway_740
Member - Posts: 13
Posted: April 20, 2010 at 1:33 PM / IP Logged
disconnecting the ground wire from the unit and disconnecting the negative battery terminal under the hood are essentially the same thing.
KPierson
Posted: April 20, 2010 at 1:39 PM / IP Logged
No it's not, it's not even close.
Many alarm systems and remote starts will still work if you disconnect the ground - they pull ground references from other inputs.  If you are going to disconnect something from the remote start disconnect the main harness on the unit.
Kevin Pierson
