2008 mazda 3 and viper
leoleo
Member - Posts: 18
Posted: May 06, 2010 at 12:55 PM / IP Logged
i have question regarding mazda 3..
this car has factory alarm..i know mazda3 without factory alarm is 1 wire system needs 1k resistor..
but with factory there is arm and disarm wire(with double pulse to unlock)..compustar has option to unlock before start and relock after start..that is not a problem..
but with dei product, there is no option to it..
what should i do? using lock/unlock from dei to arm/disarm wires to car side?it will disarm but won't unlock door right?
which way is the best?
1. arm(dei) to arm(car side) and use relay  with 1k resistor to lock/unlock wire(car side) to lock and disarm(dei) to disarm(car side) and unlock(dei) to unlock(car side)?
2. lock(dei) to arm(car side) and unlock(dei) to disarm(car side) and program ign lock and unlock?
3. 2nd igntion to keysense wire to disarm without unlock door? or is this not working with mazda 3?
blanx218
Silver - Posts: 654
Posted: May 06, 2010 at 10:09 PM / IP Logged
what viper system are you using?
syl20rochon
Copper - Posts: 298
Posted: May 07, 2010 at 2:09 PM / IP Logged
arm is: BLACK/ blue (-) (In driver kick panel)
disarm is: BLACK/ white (-) (double pulse)
Increase door lock pulse to 3.5 seconds.
Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
ctdubbin
Member - Posts: 38
Posted: May 20, 2010 at 10:12 AM / IP Logged
look at RS5 or something called "200ma status output"
my paperwork says that it can be used to activate the "keysense" wire which turns off the factory anti-theft without unlocking the doors.
syl20rochon
Copper - Posts: 298
Posted: May 20, 2010 at 6:41 PM / IP Logged
Did you try what I wrote, pdl in driver kick panel with 3.5 second pulse....I think you need double pulse to unlock...
Sylvain Rochon
I'm here to help.
tedmond
Gold - Posts: 4,610
Posted: May 21, 2010 at 5:05 AM / IP Logged
power up keysense, it will disarm.
Ted
Compustar Expert
syl20rochon
Copper - Posts: 298
Posted: May 21, 2010 at 8:17 PM / IP Logged
Yes key sense will disarm in (+) but will disable oem remotes while in remote start mode. It's preferable to use the arm and disarm wires in the driver kick panel with door lock pulse programmed in 3.5 seconds.
connect your lock and re-arm wires together, do the same with unlock and disarm. While remote starting, the short pulse from the disarm wire will disarm the oem alarm without unlocking the doors, the 3.5 pulse of the power door lock wires will unlock all doors together in one shot. I've done hundreds that way and it works very good.
Sylvain Rochon
I'm here to help.
blanx218
Silver - Posts: 654
Posted: May 21, 2010 at 10:17 PM / IP Logged
I always use the purple 2nd starter (-) output to rearm on DEI stuff and lt GREEN/ black to disarm
ctdubbin
Member - Posts: 38
Posted: May 24, 2010 at 2:42 PM / IP Logged
good information, thank you, but a quick question.
would this setup also work if i were to program the door lock pulse to .8 seconds? i want to keep my factory setup, which is single pulse to unlock drivers door, double pulse opens all others.
im guessing a 3.5second pulse emulates a double pulse.
ctdubbin
Member - Posts: 38
Posted: June 03, 2010 at 12:04 AM / IP Logged
my mazda still unlocks the doors when it remote starts. i can't find a feature that i can turn off or on that could be the cause of it.
also, setting the 3.5 second door lock kills the ability to only unlock the drivers door, even with the remote keyless entry.
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
