2010 tundra reverse wire, xk05 programming
dannyDEI
Posted: June 30, 2010 at 10:27 AM / IP Logged
Ok 2 quick questions.
1. Where can I find the reverse wire on a 2010 toyota tundra double cab?
2. I bought the XK05 bypass and was told 2 keys are required however the instructions dont mention the second key. They basically say wire it, connect it, turn the key to ign and the red light on the bypass turns solid, start truck with key, the solid red light goes out and the bypass is programmed. Where do you use the second key?
Mike M2
Platinum - Posts: 2,652
Posted: July 01, 2010 at 6:11 AM / IP Logged
It's a blue wire in the passenger kick panel.
Don't know the XK, but i have never seen a bypass in a Toyota need two keys....
Mike M2
Tech Manager
CS Dealer Services
Platinum - Posts: 7,828
Posted: July 01, 2010 at 6:58 AM / IP Logged
What firmware is loaded on the XK05?
 I have used and prefer the 5.PKTI firmware ( over the PKT2 firmware ) on earlier Tundra's.  It is an easier install and works great.  Either way you should need only one working key.
ajstetler
Copper - Posts: 94
Posted: July 03, 2010 at 11:23 PM / IP Logged
I prefer the PKALL over the XK05...
Big Al
jmsounds
Copper - Posts: 99
Posted: July 12, 2010 at 1:10 PM / IP Logged
i don't know about you guys but i had a problem with a 09 tacoma when programing the module would not program i though i was doing something wrong i try a differente module same thing then i call tech support and they told that that some toyotas you have to try different keys if it does not work i did this and it work but only happened once
but to program you only need one key if the first does not work try a second key hope it helps
Mike M2
Posted: July 12, 2010 at 2:17 PM / IP Logged
You cannot use the gray valet key....
Mike M2
Tech Manager
CS Dealer Services
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
