door open on remote
matthewjon
Member - Posts: 40
Posted: August 02, 2010 at 6:14 PM / IP Logged
Hi,
After arming the Viper 5901, my remote tells me "door open." Went around and made sure the doors were closed. Tried it again, same thing.
So I roll the windows down, and arm the alarm. I unlock each door and I find the alarm isnt picking up when either front door is opened. The rear doors trigger the alarm.
The factory alarm goes off when I open the front drivers door, but not when I open the front passenger door.
Viper 5901 alarm with an Idatalink bypass. Ive had it installed for awhile now, with zero issues. It just started doing this today.
I have it soldered W2W. Everything is heat shrinked or taped up good. I checked the door trigger wire going to the bypass and it seems to be a solid connection.
Think the bypass is the issue? Or is there something that I overlooked?
THanks, Matt
matthewjon
Member - Posts: 40
Posted: August 02, 2010 at 6:15 PM / IP Logged
FOrgot.
2007 GMC Sierra CLassic...old body style
matthewjon
Member - Posts: 40
Posted: August 02, 2010 at 11:51 PM / IP Logged
Everything else works perfect, the shock sensor, locks, R/S.
Has to be a reason why the alarm isnt acknowledging the front doors. THe domelight comes on when you open the front doors.
The siren also chirps once after the arming chirps, telling me that a door is open.
Anyone?
matthewjon
Member - Posts: 40
Posted: August 03, 2010 at 5:59 PM / IP Logged
No idea why the front doors aren't being picked up?
dasbogie
Silver - Posts: 514
Posted: August 03, 2010 at 6:19 PM / IP Logged
have you tried reprogramming the idatalink piece?
Advanced
matthewjon
Member - Posts: 40
Posted: August 03, 2010 at 8:53 PM / IP Logged
Good heads up! Reprogrammed the bypass and all is well..for now. Any idea why that happened? No work has been done on the truck, so it isnt like the battery was disconnected.
Anyways, thanks!
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
