ford gold alarm glass/shock sensor?
tikt b8
Posted: August 11, 2010 at 3:42 PM / IP Logged
I am installing an OEM Ford Gold alarm in my 07 Expedition and I want to add a perimeter/shock and window sensor to it. Will the DEI 506 T or Code Alarm CA-GBS work on this alarm? What about the 508 D or the CA-9492 for the shock sensor? I know that the 508 D will work on OEM GM alarms but this is my first ever ford and cannot find this information. Thanks for any help.
lgrammer
Member - Posts: 20
Posted: August 13, 2010 at 12:03 AM / IP Logged
not to be a bug but i hope you got the unit free or really cheap cause the factory ford alarm system are junk. They are made by code alarm so i dont see why not but i have never hooked up an extra sensor to them
tikt b8
Posted: August 29, 2010 at 3:53 PM / IP Logged
I got the alarm for right above cost and I am an OEM junkie for this car. I just like the functionality of OEM stuff.
But, just an fyi, but these can be incorporated into the stock alarm. My stereo shop used a relay and the hood pin to connect the 506T and it works great. The relay was used to reverse the polarity of the door trigger into a negative signal for the 506T. It works great. The other sensors (508 D, etc) can be hooked up in a parallel with the 506T as well.
