wire puller tool
start25
Copper - Posts: 114
Posted: September 10, 2010 at 1:58 AM / IP Logged
Hello installers...  Does anybody know where to get wire puller tool that you can use to pull a wire through door firewall and that rubber cover that goes from the door to kick panel?  I used to have this white bendable plastic tool and I totally forgot where I bought that.  Please help me find a good tool for that.
Thanks a bunch!
start25
Copper - Posts: 114
Posted: September 10, 2010 at 2:25 AM / IP Logged
I found it!  wire puller tool -- posted image.
Its called Pro. Fit Wireworm
http://www.crutchfield.com/p_042DM4533/Pro-Fit-Wire-Worm.html?tp=990
godd dan it
Copper - Posts: 447
Posted: September 10, 2010 at 4:58 AM / IP Logged
Thanks for posting this. Im gonna go ahead and buy this tool. Been trying to use a metal clothes hanger to route wires. It works in some cases, but not all.
kgerry
Platinum - Posts: 3,455
Posted: September 10, 2010 at 9:58 AM / IP Logged
DEI sells them too..... 647T
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
dasbogie
Silver - Posts: 514
Posted: September 10, 2010 at 2:19 PM / IP Logged
a conductor removed from a piece of 14-2 works quite well also.  usually I remove the white or neutral wire, it's a little easier to see rather than the black or the gound uninsulated wire.
Advanced
KPierson
Platinum - Posts: 3,527
Posted: September 10, 2010 at 7:57 PM / IP Logged
Go to Home Depot or Lowes and go back to the air duct section - you should be able to find very long, thick zip ties. Cut the square end off and drill a few holes through that end to weave wires through. It works really well.
Kevin Pierson
Wednesday, January 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
