python 991, 2010 dodge ram
phillymac23
Posted: September 11, 2010 at 2:25 PM / IP Logged
I had a Python 991 installed in a 2010 Dodge Ram.  Everything works great but I noticed that the installed zip tied the brain under the dash and used T and crimp connectors and zip tied the wires.  I doesn't look bad but from all the videos I watched on you tube this is a no no.  Should I be concerned?
t&t tech
Platinum - Posts: 2,622
Posted: September 11, 2010 at 4:31 PM / IP Logged
Well generally these connectors are a "no, no," for guys who have passion for doing their work the right way the first time, (which leaves your installer out of this bracket), they may eventually loosen over time and the connections can fall apart, leaving you in problems, and they aren't any where near as safe and reliable as if the connections were soldered and taped, period.
