firmware update for cm6000
tianot
Copper - Posts: 155
Posted: September 22, 2010 at 8:01 AM / IP Logged
hello guys, anybody here know how to update the firmware for cm6000? im having a problem programming my cm6000 unit using my op500. i dont have a firstech account.
i have a  idatalink weblink updater and a y cable.
thanks
tianot
tedmond
Gold - Posts: 4,610
Posted: September 22, 2010 at 8:26 AM / IP Logged
with the adsusb adapter you should be able to upgrade the brain from idatalinks website with weblink.
do you have a blade module in it?
if not you need a valet switch and the y cable from the op500
Ted
Compustar Expert
tianot
Copper - Posts: 155
Posted: September 22, 2010 at 9:08 AM / IP Logged
ted,
i dont have a blade module. i have the op500, the y cable and the ads usb cable.
what is the valet switch? is that the switch from the cm6000 unit or the switch from op500?
if the valet switch from the cm6000 your talking about, how can i update the firmware of the cm6000?
thanks
tianot
phil6710
Copper - Posts: 89
Posted: September 24, 2010 at 10:57 PM / IP Logged
you should be able to program the compustr with out updating if   you want to update it connect theantenna wire from the compustar to the uart(RS232) port and the other end to the weblink updater then goto idattalink.com and "Flash your module" A quick question, what option are you tring to program?
