need wire list for 2008 vw eos
Thack79
Silver - Posts: 526
Posted: October 18, 2010 at 7:41 AM / IP Logged
could someone post a tech sheet for the 2008 VW Eos.
Thanks,
Platinum - Posts: 7,828
Posted: October 18, 2010 at 7:55 AM / IP Logged
Here is info from Bulldog Security:
VOLKSWAGEN
 MODEL  YEAR(S)
 EOS   2007 -2008
 KEY  T-HARNESS  IMMOBILIZER
  N/A    N/A    VW'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1
 PART           COLOR                LOCATION
 12 VOLT CONSTANT   RED (+), 50 AMP    @ FUSE BOX, (PIN 38), NOTE #2
 STARTER  RED / BLACK (+)   @ VESCM, (12-PIN PLUG(G), PIN 1, NOTE #3
 STARTER 2  N/A
 IGNITION 1  BLACK (+)  @ VESCM, (12-PIN PLUG(G), PIN 11, NOTE #3
 IGNITION 2  N/A
 IGNITION 3  N/A
 ACCESSORY /HEATER BLOWER 1  N/A
 ACCESSORY /HEATER BLOWER 2  N/A
 KEYSENSE  N/A
 PARKING LIGHTS ( - )  N/A
 PARKING LIGHTS ( + )  GRAY / YELLOW (+)   @ HEADLIGHT SWITCH or VESCM, (16-PIN PLUG(E), PIN 1, NOTE #3
 POWER LOCK  BROWN / GREEN (-), NOTE #4, See DIAGRAM   @ DDCM, (20-PIN PLUG), PIN 32, NOTE #5
 POWER UNLOCK  Use LOCK wire, (-) thru a 250 Ohm Resistor to UNLOCK
 DOOR TRIGGER  BROWN / YELLOW (-)   @ DDCM, (20-PIN PLUG), PIN 7, NOTE #5
 DOMELIGHT SUPERVISION  RED / PURPLE (-)   @ VESCM, (12-PIN PLUG(B), PIN 11, NOTE #3
 TRUNK RELEASE  PURPLE (-)   @ CSCCM, (8-PIN PLUG), PIN 6, NOTE #6
 SLIDING POWER DOOR  N/A
 HORN  BLACK/ WHITE (+)   @ VESCM, (16-PIN PLUG(J), PIN 6, NOTE #3
 TACH  NOTE #7   @ Any FUEL-INJECTOR
 WAIT TO START LIGHT  N/A
 BRAKE  BLACK/ RED (+)   @ BRAKE PEDAL SWITCH or VESCM, (16-PIN PLUG(E), PIN 2, NOTE #3
 FACTORY ALARM DISARM   NOTE #8   @ DDCM, (20-PIN PLUG), PIN 16, NOTE #5
 ANTI-THEFT  VW'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1   @ IGNITION SWITCH TUMBLER
EXTRA INFORMATION
NOTE #1: VW'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part # 791 Bypass Module, for REMOTE STARTING ONLY! Part # DLPK-CANBUS MULTI for REMOTE STARTING and DOOR LOCKS (Resistors for DOOR LOCKS, NOT REQUIRED)
NOTE #2: the FUSE BOX is located at the LEFT END of th DRIVERS DASH.
NOTE #3: the VESCM, (Vehicle Electrical System Control Module) is the RELAY BOX, Under the DRIVERS DASH.
NOTE #4: this vehicle uses a 1-WIRE DOOR LOCKING SYSTEM, that Requires Extra Parts for operation. See DIAGRAM. The use of Bypass Module DLPK-CANBUS MULTI will do the ANTI-THEFT and DOOR LOCKS without the use of relays and resistors.
NOTE #5: the DDCM, (Drivers Door Control Module) is located in the DRIVERS DOOR.
NOTE #6: the CSCCM, ( Comfort System Central Control Module) is located behind the GLOVE BOX.
NOTE #7: when using the TACH wire, use any wire NOT with a RED STRIPE(2.0T Engine) or a RED / BLACK(3.2 Engine) both test (AC)
NOTE #8: to DISARM FACTORY ALARM (if needed) Requires a (-) thru a 250 Ohm Resistor on the GREEN / WHITE (-) wire, requires resistor and relay. TEST this wire while turning the KEY in the DRIVERS DOOR.
Audiovox has it also :  http://techservices.audiovox.com/Login.aspx    Sign up is free.
Thack79
Silver - Posts: 526
Posted: October 18, 2010 at 8:04 AM / IP Logged
thanks man
