Posted: November 09, 2010 at 9:54 PM / IP Logged
Posted: November 09, 2010 at 10:49 PM / IP Logged
Posted: November 10, 2010 at 12:20 AM / IP Logged
Posted: November 10, 2010 at 9:33 AM / IP Logged
Posted: November 10, 2010 at 3:23 PM / IP Logged
Posted: November 10, 2010 at 4:52 PM / IP Logged
Posted: November 10, 2010 at 5:03 PM / IP Logged
Posted: November 10, 2010 at 5:21 PM / IP Logged
Posted: November 10, 2010 at 5:31 PM / IP Logged
Posted: November 10, 2010 at 5:46 PM / IP Logged
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
For my edification. . . . I know relays can serve many purposes. . . In this case what are the relays doing?
Question 2: Thanks. . . . that will save a little work.
Question 3: On the remote starter I have a 30amp Select Output Wire - Selectable output for 2nd Ign, acc or starter.
Is this the wire I would use and reverse the polarity to the brown and yellow wire at/on the clutch switch? What would I set the 'jumper' to? Ignition or starter?
Would I then reverse the polarity with a relay and wire it as shown below?
Do I need to first test the brown and yellow wire? If so, what do I test for?
Question 4: I have a soldering iron. . . . . what type of solder should I use?
Thanks again for your help. I am one of those that while I like to save a buck. . . . I really like the challenge and experience of learning something new!
I don't need bypass (black key) so my - while running wire is unused. How can I confirm low current (-) as KarTuneMan suggests? I have an analog amp meter. .. . just need to know what to do and what to test for. Assuming it is low current. . . Would I just use the - while running wire as shown below and connect it to the brown and yellow wire at/on the clutch switch?
Thanks for your help.
