au 93 window roll up trouble
homeinstaller
Member - Posts: 6
Posted: December 09, 2010 at 9:06 AM / IP Logged
I have an au-93 in a 98 monte carlo hooked up to a 350 viper alarm. when i arm the drivers window rolls up all the way but the passangers window moves up an inch or so then stops. i spliced between switch and motor . the au-93 is an older model with no adjustments for increasing or decreasing the power to the motor.
could anyone help ? thank you.
first post hope i did it right.
Posted: December 09, 2010 at 1:30 PM / IP Logged
Try a thicker power lead directly to the battery fused at the battery, also a thicker ground return pref to a really good ground, that is measure the resistance between batt neg and your grounding point, should be 1 ohm or less.
t&t tech
Platinum - Posts: 2,621
Posted: December 09, 2010 at 5:25 PM / IP Logged
That unit rolls one window at a time so it really doesn't require a large power source and since it's doing the driver window i think the power and ground's ok, the unit will stop if the windows are to stiff.
homeinstaller
Member - Posts: 6
Posted: December 09, 2010 at 6:34 PM / IP Logged
I tested my power sources . And all tested good . Next I oiled the window tracks ,manually ran the window a few times ,than I tested the au-93 ,and yes the window works now .  Thank you guys. I thank you for your time. au 93 window roll up trouble -- posted image.
t&t tech
Posted: December 10, 2010 at 8:19 PM / IP Logged
Works every time. au 93 window roll up trouble -- posted image.
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
