2000 windstar remote start problem
edzwasel329
Member - Posts: 8
Posted: December 17, 2010 at 12:02 AM / IP Logged
i have ford 2000 windstar and i stalled a prostart ct-3471, ill check all wire color are correct, but its does'nt start when the ignition key are not in the igniton barrel, and heater fan, and park light is not working also! anybody to figure out this... thank's for your help merry x-mass!!
zerepdivad
Silver - Posts: 605
it doesn't start without the key in the barrel? hmm think about that one for a second....
A DMM is a beautiful thing.
edzwasel329
Member - Posts: 8
Posted: December 17, 2010 at 12:11 AM / IP Logged
what is the best way and i need an additional part to start it w/out the key?
edzwasel329
Member - Posts: 8
Posted: December 17, 2010 at 12:14 AM / IP Logged
actually i have also a 1999 dodge caravan and i stalled it. everything works fine! not on my ford windstar..
zerepdivad
Silver - Posts: 605
Posted: December 17, 2010 at 12:32 AM / IP Logged
buy a pkall
tedmond
Gold - Posts: 4,610
Posted: December 17, 2010 at 8:37 AM / IP Logged
windstar uses multiplex (resistive) parking lights, there are mutiple ignitions and accessories, so power them all up as INDIVIDUAL circuits or else the heater wont run
as far as bypass, you will need 2 keys for programming. use anything from idatalink, fortin, or expresskits.
Ted
Compustar Expert
tommy...
Gold - Posts: 1,901
Posted: December 17, 2010 at 9:38 PM / IP Logged
You can use the FLTBF or the 556U for the bypass...(Must give up a key for the 556u)...You have not properly wired the ignition harness to the r/s harness...Take the time and post your connections...! Do you have a DMM or just praying that it's right...? You will need to wire up relays to power the "extra" ignition and accessories wires...Look on on this site under relay's for that info...!
Remote Start 2000 windstar remote start problem -- posted image.
2000 windstar remote start problem -- posted image. WIRE 2000 windstar remote start problem -- posted image. COLOR 2000 windstar remote start problem -- posted image. POLARITY 2000 windstar remote start problem -- posted image. LOCATION 2000 windstar remote start problem -- posted image.
Battery LIGHT GREEN/ VIOLET (+) IGNITION SWITCH HARNESS
Ignition 1 WHITE/ YELLOW (+) IGNITION SWITCH HARNESS
Ignition 2 VIOLET/ORANGE (+) IGNITION SWITCH HARNESS
Accessory 1 VIOLET/ORANGE (+) IGNITION SWITCH HARNESS
Accessory 2 YELLOW (+) IGNITION SWITCH HARNESS
Accessory 3 BLACK/ GREEN (+) IGNITION SWITCH HARNESS
Starter 1 GREEN (+) IGNITION SWITCH HARNESS
Anti-Theft Type RF ACTIVATED SYS.
Anti-Theft Descript PATS
Key Sense BLACK W/ VIOLET DOTS (-) IGNITION SWITCH HARNESS
Neutral Safety WHITE/ PINK (-) USE STARTER WIRE
Tachometer PINK/WHITE (-) PCM RIGHT SIDE INST PNL PIN 78(2 CYL SET
Speed Sense GREEN / WHITE (AC) PASS REAR OF ENG POS 58 OF 104 PIN PLUG
Parking Lights YELLOW/LIGHT BLUE (-) PIN 21 OF 22 PIN CONN FRONT BCM LEFT DAS
Low Crr. Pk Lights BLACK/ GREEN (-) HEADLIGHT SWITCH
Brake Lights RED / LIGHT GREEN (+) AT SWITCH ABOVE BRAKE
Reverse Lights LR:GREEN/ ORANGE (-) RR:WHT/YEL PIN 9+10 OF 17 PIN REAR BCM
MAY ALSO BE WHITE/ YELLOW
Horn ORANGE / RED (-) PIN 8 OF 12 PIN CONN FRONT BCM
Modules 2000 windstar remote start problem -- posted image.
2000 windstar remote start problem -- posted image. WIRE 2000 windstar remote start problem -- posted image. LOCATION 2000 windstar remote start problem -- posted image. 2000 windstar remote start problem -- posted image. 2000 windstar remote start problem -- posted image.
Module 1 HIGH DR.KICK
Module 2 BCM - LEFT SIDE OF DASH (FRONT) RIGHT REAR QUARTER PANE FRONT ELECTRONIC MODULE (FEM)
Module 3 PCM - RIGHT SIDE OF DASH
M.E.C.P & First-Class
Monday, January 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
