530t for sun roof 02 acura tl
laziebun
Member - Posts: 39
Posted: January 11, 2011 at 5:40 PM / IP Logged
I have a 2002 acura TL type S and i am installing a viper 5902 with a 530t(2) for four windows and a 530t for the sun roof. Question that i have is, how do i go about installing it for the sun roof to get the tilt to work?? if anyone has done this before, windows or sun roof and have any tips please chime in.
tedmond
Gold - Posts: 4,610
Posted: January 11, 2011 at 8:55 PM / IP Logged
use a 529t for the sunroof instead.
Ted
Compustar Expert
tomslik
Posted: January 12, 2011 at 2:18 AM / IP Logged
You can use either the 529t or the 530t, it doesnt matter. Now for the sunroof. You need to go directly to the motor wires and put your module inline up their. because most likely your switch is up their to. I ran some heavy ga. speaker wire up their, and put the module in the dash.  Now for sunroof tilt!!!!!!!!!!!!! If your sunroof is closed, and you've hooked up your windows to close when you arm your vehicle, your sunroof will open to tilt. If interested, I will tell you how to stop this from happening...........................
laziebun
Member - Posts: 39
Posted: January 12, 2011 at 8:38 AM / IP Logged
Tomsilk plase share your knowledge on how i can prevent my sunroof from tilting when i arm it, if the sun roof was already in the closed position. "best knowledge is shared knowledge"
laziebun
Member - Posts: 39
Posted: January 14, 2011 at 11:53 AM / IP Logged
tomslik where are ya man!!
