remote start 12 v power wire
ricardoboston
Copper - Posts: 268
Posted: January 26, 2011 at 6:50 AM / IP Logged
some cars dont use 12v high amp so you have to go to the battery for the remote starter power, in some cases some cars use only 10amp 12 v for the power wire in this case can i remove the original fuses from the remote starter and use one 5amp just to get a little lower of the original of the car?
Twelvoltz
Platinum - Posts: 2,384
Posted: January 26, 2011 at 7:31 AM / IP Logged
It really depends on the draw of the system you are installing. However, with the DEI systems I use, I do exactly what you are asking. I remove the included 30 amp fuses and replace them with what the vehicle's ignition wires are rated at. Because the DEI systems I use do not have a separate fuse for parking light input I use negative parking lights to ensure the system draw is minimal.
ricardoboston
Copper - Posts: 268
Posted: January 26, 2011 at 11:25 AM / IP Logged
ok so will be not problem running a remote starter with a 5 ,10,15,20,  fuse? i can see this like be more safer right thanks.
Mike M2
Platinum - Posts: 2,652
Posted: January 26, 2011 at 3:04 PM / IP Logged
As long as it is enough to control the ignition of the car. I never go under the hood for power tho. If i can't get it from the switch i may use power from the BCM...
Mike M2
Tech Manager
CS Dealer Services
Posted: January 26, 2011 at 4:35 PM / IP Logged
And to add to Mike's comment, if in doubt go to the battery other wise a good candidate is usually the main constant (from battery) power supply to the fuse box.
