07 f250 viper 5901 check up
shane.lucero
Posted: March 10, 2011 at 6:58 PM / IP Logged
I'm looking for some assistance on installing my alarm!
I have been doing some research over the past week using the12volt.com forum, reading the Installation Guide , reviewing my Wiring Schematic as prepared by DirectWire, Directed Electronics.
  With all of the reseach that I have done , I have created a spread sheet that indicates where everything is to be hooked up. So I was hoping that somebody that has actually installed this system on my same year can give me some input on what I have put together.  Also for those that have installed this on thier 2006 F250, this year has a GEM unit and my year, 2007 doesn't, it has what is called a VSM so the wiring is a bit different as it pertains to the Dome Light.
Alarm: Viper 5901 Responder LC3 SuperCode SST 2-Way Security and Remote Start System5702V
Alarm Accessories: 520T Back up battery
Truck: 2007 F250 SD 6.0 L Diesel
Factory Alarm: NO
Keyless Entry: Yes
Progressive Locks: Yes (would like to maintain)
Dome Delay: YES
VSM: YES
GEM: NO
IF anyone would like I can email them my spread sheet where I have all of my notes and comments organized along with the information listed below.  Any comments will be greatly appreciated.
Also, I would be willing to share my spread sheet with anyone that is also looking to install this Viper unit on thier 2007 F250.
Primary Harness (H1) , 12-pin Connector
H1/2 (+)12V Constant
Yellow (30a), Lt grn/pur (30A) wires located at  Ignition Harness   or Direct to Vehicle Battery (+) 12V Constant Input
H1/3 (+) Siren Input
(+) Siren Output Located at Siren
H1/4 Light Flash Isolation Wire – Pin 87a of onboard relay
Connect to Relay (Refer to H1/9)
H1/5 Chassis Metal
(-) Chassis Ground
H1/6 (+) Door Trigger Input
Connect to Dome Supervision – (BLACK/ Lt. Blue) Wire Located at Rear of Drivers Door Sill Plate Harness.
H1/7 (-) Trunk Pin / Instant Trigger Input (N/C or N/O)
Connect to 520T Backup Battery
H1/8 (-) Door Trigger Input (N/C or N/O)
Not used
H1/9 (-)200m Dome Light Output
 BLACK/ Lt. Blue Wire at Passenger Kick or Cluster.   Blue Plug Pin 26 (Relay Required)
H1/10 (-) Remote start/turbo timer activation input
Push Button
H1/11 Parking Light Output
Brown Wire Located at Switch or VSM  green plug pin2
H1/12 (-) 500mA Ground When Armed Output
 Not Used
Relay Wiring - Dome Light Supervision
 Pin85 Wired to H1/4 at Viper BLACK/ White (Light Flash -Isolation Wire - Pin 87a of onboard relay)
 Pin87 Wired to H1/9 at Viper  WHITE/ Brown (Domelight Supervision Polarity (+) or (-))
 Pin86 Wired to 12V constant Wired to +12V constant Fused
 Pin30  Wired to Dome Light Supervision Factory Wire (Black / Lt. Blue @ Passenger Kick or cluster, (blu plg, pin 26) Also found in the driver side kick panel on some models.
 Harness (H2), 18 pin connector
 H2/1 Factory Alarm Disarm Output
Wire to (528T BLACK/ White) (Per Tech Doc 1091)
H2/2 (-) 200 mA Auxilary 4 output
 Not used
H2/3 (-) 200 mA OEM Alarm Arm Output
 Not Used
H2/4 (-) 200 mA Auxilary 2 Output
 Not used
H2/5 (-) 200 mA Auxilary 3 Output
 Not used
H2/6 (-) 200mA Auxilary 1 Output
 Not used
H2/7 (-) Diesel wait to Start
Wire to 528T  Brown wire. (Don’t connect to Factory “Wait to Start”)
H2/8 (-) 200mA Horn Honk Output
Dark Blue wire at switch or VSM, green plug, pin 6
H2/9 Tachometer Input Wire
Don’t connect wire use Virtual tach- Programming Only.
H2/10 (-) 200 mA Status Output
 Not Used
H2/11 (-) 200mA Flex Relay Control Output
 Not Used
H2/12 (-) 200mA Accessory Output
 Not Used
H2/13 (-) 200mA Starter Output
 Not Used
H2/14 (-) 200mA Ignition 1 Output
 Not Used
H2/15 N/O or N/C (-) Hood Pin Switch input
 Under Hood
H2/16 (-) 200mA 2nd Status /Rear Defogger Output
 Not used
H2/17 (+) brake shutdown input wire
Lt. Green at Break Pedal Switch
H2/18 (-) Neutral Safety Switch Input
 Automatic transmission Wire to Ground (Chassis)
Tech Tip 1091 (Diesel wait to start with timer)
528T BLACK/ White
 Wire to H2/1 GREEN/ Black
 528T Brown
Wire to H2/7 Gray /Black
528T Orange
 Not Used
528T Yellow
 Ground
528T Black
 Ground
528T Red
 (+)12v constant
Heavy Gauge Remote start, (H3) 10 Pin connector
H3/1 (+) Ignition 1 Input/Output
 Red / Lt. Green at Ignition Harness
H3/2 (+) Fused (30A) Ignition 2 / Flex Relay Input 87
 (+) 12v constant
H3/3 (+) Accessory Output
Accessory 1 -Grey / YELLOW and RED / Black wires located at Ignition Harness.
Question: Will a relay be necessary if there are two Acc. 1 wires?
H3/4 (+) Starter output (car side of the starter kill)
Dk. Green at Ignition Harness
H3/5 (+) starter input (key side of the starter kill wire)
H3/6 (+) fused (30a) ignition 1 Input
(+) 12v constant
H3/7 (+) Ignition 2 / Flex Relay Output
Accessory 2-dk. Blue/Lt. Green at Ignition Harness
H3/9 (+) Fused (30a) Accessory/Starter Input
(+) 12v constant
H3/10 N/C
 Not Used
Door Lock Harness, 3-Pin Connector   (Type-A: Three-wire (+) pulse)
1  (-) 500 mA Unlock Output
Pink / Black at Driver Kick or VSM, Gray Plug, Pin 1
2 Empty
 Not Used
3  (-) 500mA Lock Output
Red / Orange Driver Kick or VSM, Gray Plug, Pin 7
[END]
Platinum - Posts: 7,828
Posted: March 10, 2011 at 7:19 PM / IP Logged
Both Bulldog and Audiovox list 2 Ignition wires and two Accessory wires.  Best to verify this with a DMM.  And yes, use a 30/40 Amp SPDT relay for ACC2.  Wire as follows:
Relay Pin 86 and 87 to +12v constant fused at 20 Amps
Relay Pin 85 to Viper H2/12
Relay Pin 87a not used - insulate
Relay Pin 30 to ACC2 at F250 ignition harness
Did you verify that your truck does not have the PATS immobilizer?  ( Some do. )
If Virtual Tach does not work properly, here is Diesel Tach info from Bulldog:
On DIESEL Engines the TACH wire is a LIGHT GREEN / WHITE wire in a 5-Pin Harness held up with WHITE tape located behind the Parking Brake Release.
shane.lucero
Posted: March 10, 2011 at 7:51 PM / IP Logged
Thanks for the reply, I greatly appreciate it.
What is throwing me off is that the DEI Wiring lists the following:
ACC-1 (Grey / YELLOW and RED / Black)
ACC-2 (Blue/ Lt. Green)
This would be three wires?- That's what is throwing me off.
If it is determined that ACC-1 has two wires, I will wire in a Relay as you have indicated. I will test these wire to see if there truly are two wires for ACC-1.
That's strange that Bulldog and Audivox lists 2 ignitions and Direct Wire indicates only one, I will have to look into that.
PATS- I'm not 100% Certain that my truck has a PATS- I will verify when I start the installation.  I'm prepared because I have purchased the XPRESS PKFM just in case it is needed. The wiring directions are very clear for that unit.
Was there anything else that caught your attention?   Dome Light supervision Relay wiring? Anything else?
Also, the
shane.lucero
Posted: March 11, 2011 at 11:14 PM / IP Logged
Anybody Else, have any input?
Posted: March 12, 2011 at 5:48 AM / IP Logged
If your dome light comes on either when you manually unlock or through keyless entry you won't need domelight supervision.
Also and I'm sure Kreg knows better but using a POS door trigger?
Asking questions about the number of ignition wires is moot; read my bye-line.
Posted: March 12, 2011 at 7:49 AM / IP Logged
Some more info confirming the door lock info in my previous P.M.
2007 F250  Door Locks
Vehicles with keyless entry, the lock wire is WHITE/ red (-), in the driver kick, door harness or also
at the VSM, gray plug, pin 3. The VSM (Vehicle Security Module) is to the right of the accelerator pedal
above the transmission hump below the radio. Not accessible from radio opening.
Vehicles with keyless entry, the unlock wire is BLACK/ white (-), in the driver kick, door harness or
also at the VSM, gray plug, pin 2. The VSM (Vehicle Security Module) is to the right of the accelerator
pedal above the transmission hump below the radio. Not accessible from radio opening. Vehicles with
keyless entry the VSM shuts down after the doors have been locked for a certain time period, to wake up
the system refer to Tech Doc 1094.
Posted: March 12, 2011 at 9:59 AM / IP Logged
This might give you some pointers: Profile Kevin Pierson, look at his posts, about 3 years ago the post is started by him so it's quite easy to find, page 6 I believe, Viper 5901 R/S in an 05 F150.
There are photos galore.
shane.lucero
Posted: March 21, 2011 at 6:59 PM / IP Logged
Thanks for everyone's input-- The alarm is working good. However, I'm having an issue with running my battery out of juice.
When I leave the Heater or vent on after I shut off the truck the heater or vent continues to run, therefore running my battery out of juice. If I turn of the Heater or Vent before I shut down the truck there is no issue with my battery running down. I have included the wiring diagram as it is currently installed.
Also, I have tested the Wiring Harness and have determined the following: 1-Ignition wire / 3-Accessory wires / 4-(+) 12v wires
Ignition Wiring harness
RED / Black- Accessory #1 wired directly into Viper alarm with built in relay
RED / Lt. Green- Ignition
Gray / YELLOW- Accessory #3 wired into Relay
Yellow- (+)12V
Yellow- (+)12v
Blue/Orange- (+)12v
Blue/Lt. Green- Accessory #2 wired directly into viper alarm with built in relay
GREEN/ Purple- (+)12v
(+) 12V Constant Input GREEN/ Purple at Ignition Harness
Not Connected
H1/5 Chassis Metal
(-) Chassis Ground
Not Used
Not used
Not used
Not Used
Brown Wire Located at  VSM  green plug pin2
 Not Used
 Not used
 Not Used
 Not used
 Not used
 Not used
Dark Blue wire at VSM, green plug, pin 6
 Not Used
 Not Used
Accessory #3 Wired to PIN 85 Relay
 Not Used
 Not Used
 Under Hood Pin Switch
 Not used
528T BLACK/ White
 528T Brown
528T Orange
 Not Used
528T Yellow
 Ground
528T Black
 Ground
528T Red
 (+)12v constant
 (+) 12v constant (Yellow)
Accessory 1 -RED / Black
(+) 12v constant
(+) 12v constant GREEN/ Purple at Ignition Harness
H3/10 N/C
 Not Used
Relay Wiring Accessory #3
Pin30 Grey / YELLOW at Ignition Harness
Pin 85 (Not Used)
Pin 86 (+12v) at Ignition harness
Pin 87 (+12v) at Ignition harness
2 Empty
 Not Used
