Posted: April 03, 2011 at 3:09 PM / IP Logged
Posted: April 03, 2011 at 5:35 PM / IP Logged
Posted: April 03, 2011 at 5:49 PM / IP Logged
Posted: April 03, 2011 at 5:50 PM / IP Logged
Posted: April 03, 2011 at 7:16 PM / IP Logged
Posted: April 03, 2011 at 8:22 PM / IP Logged
Posted: April 03, 2011 at 8:40 PM / IP Logged
Posted: April 03, 2011 at 8:51 PM / IP Logged
Posted: April 03, 2011 at 9:32 PM / IP Logged
Posted: April 03, 2011 at 10:14 PM / IP Logged
Sunday, November 2, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Please correct wiring and then disconnect your bypass...put your key into the ignition switch and try to start the trunk with the remote...se what happens...
*Make sure you learn your tach.
*Make sure your remote starter is in automatic mode and not manual mode.
*Yes, your small BLACK/ white needs to be at ground.
*Make sure your large pink/white wire is configured to second ignition and not second accessory.
*the large green wire shouldn't be used unless you're using the starter kill onboard relay.
*All three red wires need to be connected to +12V. (Red,RED / white,RED / black)
*Make sure your ground is good and not loose.
