spy alarm 2 way 5000m
saolom
Member - Posts: 15
Posted: April 15, 2011 at 10:13 PM / IP Logged
Hi
I just purchase this alarm from ebay and installing it now.
I'm having troubles with the central locking Lock and Unlock.
My car is a Honda Acura RSX base 2006 with remote locking already but want to use OEM alarm.
CAR LOCK is WHT/BLU
CAR UNLOCK is WHT/GRN
SpY alarm has 6 wires in total for the central locking
( orange,yellow,white )
How do I connect 6 of these wire onto 2 wires from the car?
Do I need 6? Usually I just have 2 wire from alarm on 2 from car?
How do I test which is lock and unlock on the SpY alarm?? this is where I'm doing my head in 12hrs to figure out! lol
spy alarm 2 way 5000m -- posted image.
please ignore the writing on the pictures.
saolom
Member - Posts: 15
Posted: April 15, 2011 at 11:01 PM / IP Logged
Any help would be awesome,
Posted: April 16, 2011 at 5:56 AM / IP Logged
Use lock diagram F2.
Posted: April 16, 2011 at 5:58 AM / IP Logged
Oh and unless 5000m is a part number, expect a range of about 5 metres, that's if it even works. buy from Fleabay? Good luck.
saolom
Member - Posts: 15
Posted: April 16, 2011 at 9:44 AM / IP Logged
yes the Alarm is from ebay, but for a decent price with good features I didn't mind trying it out on a tight budget and wanted to install myself to save as I'm a full time student.
The Alarm is SPY 2WAY 5000mtr.
with the diagrams #2 do I have to use a relay? if so how would I hook it up?
I used a test light to test the wires but no 12v coming out.
I have completed all the wiring today but stuck on these door locks!
nearly done! =)
saolom
Member - Posts: 15
Posted: April 16, 2011 at 10:05 AM / IP Logged
hi Howie 11,
I'm hoping this is how I should hook it up? do I need 12v power also to 87a?
Thanks for your help!=)
saolom
Member - Posts: 15
Posted: April 16, 2011 at 10:06 AM / IP Logged
oops picture below..
Posted: April 16, 2011 at 10:32 AM / IP Logged
It won't work and if it does you WON'T need a relay, it has supposedly on board relays and any way that relay diagram you showed will never work, you've wired it wrong, probably like the piece of junk you bought. 5000 metres or 3+ miles range??? Even Compustar, DEI all reputable products don't claim more than 1 mile (c.1500 metres) range and that would be ideal weather conditions, about 15C/50F slightly damp on a flat airfield, halve that in a city.
You get what you pay for.
saolom
Member - Posts: 15
Posted: April 16, 2011 at 10:49 AM / IP Logged
so how would I wire them?
could you give me a hand on which wires from the alarm goes to the car wires?
Posted: April 16, 2011 at 10:58 AM / IP Logged
No because from the level of competence shown I can't install this for you from 10,000 miles away. I've already told you it's diagram F2 and the alarm's white goes to the car's WHITE/ blue, the alarm's WHITE/ black goes to the car's WHITE/ green, except it won't work.
Garbage in (the product) garbage out.
Page of 3
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
