2004 lexus es 330 no remote start?
dcman41
Copper - Posts: 211
Posted: June 06, 2011 at 11:12 AM / IP Logged
Hey guys , i just installed a clifford 50.7x in a es 330 with a xpress kit pk-ALL. For some reason its not remote starting. i have powered the second ignition, with an additional relay and the second starter with the onboard relay, but the car still does not crank during the remote start sequence. The car starts fine with the key. The only thing i can think of is that i reversed the green / purple starter disable wires? Can anyone confirm this is most likely the issue ? When i arm the car and attempt to start the car with the key the starter kill kicks in and acts like it should. Also tried leaving the key in the ignition cylinder during remote start sequence, and still nothing. Any suggestions are appreciated.
-Rob
thecoolmankyle7
Copper - Posts: 77
Posted: June 06, 2011 at 2:59 PM / IP Logged
I don't know if I would call it common but if you have the starter kill is hooked up before the remote start wire that would stop it from starting. Take a test light or a meter and see is the remote start is sending power when you try to start it. The starter wire leading away from the key should inergize. Also did you verify all of your wires as you did the install or did you just follow the diagram? They can be wrong.
Posted: June 06, 2011 at 4:30 PM / IP Logged
Learn Tach.
Posted: June 06, 2011 at 4:38 PM / IP Logged
Sorry my previous answer was WRONG.
Cut starter 1, green to key side and violet (purple) to starter side and ONLY that way round.
dasbogie
Silver - Posts: 514
Posted: June 06, 2011 at 7:20 PM / IP Logged
Is the neutral safety switch plugged in and turned on?   Is the neutral safety wire seeing ground?   Did you change it from manual to automatic trans mode(if indeed it is automatic transmission)?  When you try to remote start and it fails, do the parking lights blink a sequence?
Advanced
dcman41
Copper - Posts: 211
Posted: June 07, 2011 at 2:57 AM / IP Logged
I was correct i reversed the green / purple starter wires. Everything fired up on the first try once i de pinned(easier than cutting and re soldering) them and swapped the postions of the green / purple wires of The main heavy gauge plug :)
thecoolmankyle7
Copper - Posts: 77
Posted: June 07, 2011 at 2:16 PM / IP Logged
Glade to hear you got it up and going!
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
