2006 toyota sequoia
ccourt4175
Posted: July 26, 2011 at 12:34 PM / IP Logged
Just recently purchased a python 1401 and I am having problems with the relays that must be installed for the door locks. any help would be greatly appreciated. Wiring diagrams would solve my problem.
Platinum - Posts: 7,828
Posted: July 26, 2011 at 7:16 PM / IP Logged
Here is a link to the Bulldog solution :
http://www.bulldogsecurity.com/diagrams/extrainfo/diagrams/14301_SEQUOIA_TOYOTA%20and%20LEXUS%20door%20lock%20interface.pdf
Here is a link to the Audiovox solution :
https://www.the12volt.com/installbay/file.asp?ID=661
Another way is with a "Door Lock Module".  Here is a link to the offerings from DEI :  http://www.xpresskit.com/VehicleCompatibility.aspx?p=null&year=2006&make=Toyota&model=Sequoia&ps=3&s=0     Slightly more expensive but faster...
Mike M2
Platinum - Posts: 2,652
Posted: July 30, 2011 at 7:06 AM / IP Logged
Get power for the relay from the blue/white on the door switch module. That leaves just two wires to run thru the jamb boot...
Mike M2
Tech Manager
CS Dealer Services
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
