2011 hyundai gen alarm and remote start
tagar1989
Member - Posts: 16
Posted: October 09, 2011 at 2:03 AM / IP Logged
Two questions. 2011 Hyundai Genesis. Where can i get a interface module for the key (not proximity) and can someone help me with a wiring diagram?
Thomas
Platinum - Posts: 7,827
Posted: October 09, 2011 at 2:24 PM / IP Logged
Not sure if you have the coupe or the sedan.  Also assuming it's not a Smartkey PTS.
Being as you listed Washington as your location, here is some info from iDatalink concerning a transponder :  http://12voltdata.com/viewtopic.php?f=282&t=4654
As for the wiring info, here is a link to DEI info for the sedan :  http://www.readyremote.com/main.asp?make=Hyundai&model=Genesis
They also list the coupe.
tagar1989
Member - Posts: 16
Posted: October 09, 2011 at 5:56 PM / IP Logged
So i dont need a bypass, thats kind of nuts on a new car. Its the coupe 2.0t with a regular key.
Thomas
tagar1989
Member - Posts: 16
Posted: October 09, 2011 at 6:06 PM / IP Logged
That no immobolizer post was back in 2007. Hyundai says all new hyundais have chipped keys. So my question still stands on where can i get a bypass module
Posted: October 09, 2011 at 6:22 PM / IP Logged
That post was actually from 01/18/2011.  Did a 2011 Sonata GLS non-PTS, no transponder.  Canadian models have a transponder.  But here are some links to bypass modules.
Fortin :  https://ifar.ca/en/vehicles/hyundai/genesis/2011-coupe/
iDatalink :  http://www.idatalink.com/helpdesk/
DEI  :  http://www.xpresskit.com/VehicleCompatibility.aspx?p=null&year=2011&make=Hyundai&model=Genesis%20Coupe&ps=1&s=0
tagar1989
Member - Posts: 16
Posted: October 09, 2011 at 7:10 PM / IP Logged
I stand corrected i read the wrong date. If your saying i dont need one ill go off that. If Anyone can just confirm one way or another that would be preferred. Thanks for all your help.
Posted: October 09, 2011 at 7:27 PM / IP Logged
Haven't done a Genesis Coupe but there are a few ways to check.  Here is one way.
Look for a Yellow wire at Pin 24 in the Black 39 Pin connector ( EM-51 ) in the passenger Kick Panel.  If there is no Yellow wire there, you don't have a transponder.  For more detailed diagrams of the wire and it's location, download iDatalink Install Guide #5718 ( for the iDatalink ADS-AL CA bypass flashed with ADS-AL(TB)-HK2 firmware ) and review the Type 7 Wiring Diagram.
Hopefully, some of the forum members that regularly do Hyundai's can add their knowledge.
Posted: October 10, 2011 at 2:20 AM / IP Logged
Oh boy does this confuse me, much more simple here, ALL cars registered after 01/01/97 in Europe had immobilisers.
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
