additional sensors on one mux
kaotik78
Member - Posts: 32
Posted: November 06, 2011 at 6:59 AM / IP Logged
Morning all,
I'm finishing up my alarm install and had a glass break sensor and proximity sensor in my last car. I had wired them up to the mux port using the white connector. I've just purchased a tilt sensor for my car and was wondering if I can add that to the mux connector as well?
Would it draw too much power from it with the three sensors or would it be ok? Also I would need to diode isolate all the trigger wires now so the cathode would face the sensor correct?
With the tilt sensor my plan was to power the sensor via the harness coming off my proximity sensor since they're located right next to each other, by splicing into the (+) and (-) wires, then running the orange trigger wire to the h1/12 ground when armed wire.
Posted: November 06, 2011 at 8:35 AM / IP Logged
They can all go there but diode separate the triggers please, as you thought.
Personally I'm dead set against all these sensors, too many chances of false alarms.
I don't think you can beat a decent prox, or at most shock and prox.
kaotik78
Member - Posts: 32
Posted: November 06, 2011 at 11:24 AM / IP Logged
Thanks for the input Howie! Looking at it now, the sensors I have are starting to get on the basis of overkill, really the shock,tilt and glass breakage seem sufficient , the proximity sensor would really be for someone with a convertible or jeep, which is not my car. Glad I've got this just about wrapped up as it's in the teens and single digits at night now.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
