2007 ford edge heat seaters
schmoo
Copper - Posts: 62
Posted: November 26, 2011 at 8:56 PM / IP Logged
trying to connect my factory seat heater controls to a remote start. I have fopund info that shows wht/blue and grey / YELLOW as the wires going into the heater module.  But testing shows a change on two wires  in  the 8 volt range(output side?)  Any insite?  Don't really want to mess up the heater module on this one.(it's cold up here)
a true canadian eh!
schmoo
Copper - Posts: 62
Posted: November 26, 2011 at 8:57 PM / IP Logged
some places say positive, while others say its negative.  it rest at 10 volts and goes to ground when you press the factory button, but is this just the input side before the buttons or is it the output?
a true canadian eh!
Mike M2
Platinum - Posts: 2,652
Posted: November 26, 2011 at 9:12 PM / IP Logged
Can't help with your Q, but "heat seaters" made me chuckle...
Mike M2
Tech Manager
CS Dealer Services
Posted: November 27, 2011 at 7:44 AM / IP Logged
Mike would that have anything to do with heat seekers? Or have I lost the plot? Poster here's a way to do it by avoiding the BCU just go directly to the element pos wires.
The switch lower right is optional allows you to turn it off in summer, 12v LEDs are optional but the 3 diodes, 1N4004 AREN'T.
Monday, September 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
