07 pilot disarm
ziggyb222
Silver - Posts: 593
Posted: December 28, 2011 at 4:11 AM / IP Logged
Looking for the best way to disarm the factory alarm for a remote start. Have seen some different wire colors and if you need to go into the door or not. This is a 07 Honda Pilot.. It does not have a key cylinder in the pass door... Thanks in advance for your help... Happy New Year!!!!!
metz35
Copper - Posts: 458
Posted: December 28, 2011 at 5:11 AM / IP Logged
Blue - drivers door main switch
Or passenger kick. Since you have no keyhole in passenger door there is no wire
In the plug you would have to add one. I don't remember the pin number but it's in the large plug. Maybe some one else could chime in.
mobileedgeny
Member - Posts: 32
Posted: December 28, 2011 at 5:12 AM / IP Logged
up behind glovebox there is a solid yellow wire. cut it and open with a relay. it will disarm and the factory remote key will work under remote start for a 1 button.
tedmond
Gold - Posts: 4,610
Posted: December 28, 2011 at 7:58 AM / IP Logged
this is only true for select honda vehicles 2000-2006 mainly accords.
the wire you are looking for is Pink/Black (-) behind glove box GREEN 7 Pin connector Pin 2(wire side)
Ted
Compustar Expert
