dei 1100x bypass wiring
pa_probe
Member - Posts: 20
Posted: January 27, 2012 at 1:29 PM / IP Logged
I am wiring in a Directed 1100X bypass in Mode 2 for my 2004 Toyota Sequoia. The wiring diagram is pretty clear on all of the wires for IMO, IMI, power, ground and ground when running except the Orange-Ignition Input wire on the 9 pin harness. It does not state whether this should be a Neg or Pos signal wire. There is already a ground-when-running wire (blue/white wire) that goes to teh remote starter on the 3 pin harness.   So does this wire get connected to a 12v Accessory wire or something else? I believe this is the same as the 1100F and 1100GM.
metz35
Copper - Posts: 458
Posted: January 27, 2012 at 2:19 PM / IP Logged
+ positive ignition . not accessory
