curiosity about viper 5901
soundnsecurity
Gold - Posts: 2,720
Posted: May 26, 2012 at 8:51 AM / IP Logged
i installed a viper 5901 on my 2011 nissan frontier crew cab. everything seems to work just fine but my keypad was old and beat up so i ordered a python remote and programmed it. at first it wouldnt remote start the truck, it would just say error and the original remote worked just fine. so i deleted both keypads and reprogrammed the new python remote as remote number 1 and now it works but the original viper remote now gives me the same error when i try to remote start.
it seems to me like there is some setting that wont allow remote number 2 to remote start the truck but ive looked all over and cant find any setting on the alarm using a bitwriter or on either keypad that would disable the remote start.
i know some dei alarms need to have settings programmed for each remote so i made sure they were the same and still i get nothing.
i have engine checking turned off so its not a tach learn issue.
hoping someone with more experience with these can shed some light on my situation
soundnsecurity
Gold - Posts: 2,720
Posted: May 28, 2012 at 11:52 AM / IP Logged
something else i noticed and i dont know if it is a big deal or not. when i remote start the truck and turn the key and hit the brake to take over the truck, my truck gives me a series of beeps. it does this normally with the key too but sometimes it gives me a different number of beeps. sometimes 4, sometimes 3, sometimes 2, etc, i have heard no more than 4 beeps. i assume its because when i take over the truck sees the bypass (flashlogic FLCAN)return the ignition and security light wires back to their normal state.
my only concern is why do i get a different number of beeps? is it some sort of diagnostic system and its trying to tell me something isnt right? i dont have any check engine lights on but if the truck is trying to tell me something then i want to know what it is.
triniforever
Copper - Posts: 323
Posted: May 30, 2012 at 7:36 PM / IP Logged
if i'm not mistaken and i'm assuming that the new python remote you ordered is also a pager, Viper alarms does not allow two pager remotes to be programmed to the same alarm.
triniforever
soundnsecurity
Gold - Posts: 2,720
Posted: May 30, 2012 at 9:54 PM / IP Logged
both remotes work on all functions except the second remote wont activate remote start. paging functions work on both remotes, when i lock or unlock on one remote it reports on both remotes, same for when the alarm goes off. also as i said its not a viper/python issue because both remotes are fully functional depending on the order they get programmed to the alarm.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
