Posted: August 09, 2012 at 8:37 AM / IP Logged
Posted: August 09, 2012 at 8:52 AM / IP Logged
Posted: August 09, 2012 at 12:37 PM / IP Logged
Posted: August 09, 2012 at 12:45 PM / IP Logged
Posted: August 10, 2012 at 2:39 AM / IP Logged
Posted: August 10, 2012 at 3:01 AM / IP Logged
Posted: August 10, 2012 at 3:15 AM / IP Logged
Posted: August 10, 2012 at 3:32 AM / IP Logged
Posted: August 10, 2012 at 4:31 AM / IP Logged
Posted: August 10, 2012 at 5:25 AM / IP Logged
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I started off reprogramming the remote and checking the inputs on the relevant page, all was good. Then I set the RPM starting threshold and made sure that was reading OK. I had no put the pulse/rev 20 3 to read a realistic RPM of 800. Was that correct? I also calibrated the battery voltage to what my meter read with teh engine off.
I then went to the monitor page and went through the process, the intellistart activated with the 2 winks and the box filled in Red. I took out the key, great all good so far. Got out the car and armed it. The engine DID NOT STOP. I randomly tried all sorts but to no avail.
On the monitoring page I noticed the BELOW IDLE was filled in Red, is this correct?
Also what is the 'retained accessory power off/on' do? Anything else I have missed?
Hope you can help out one of your buddies from across the pond
Lee
PS on the starter view page I could pulse the starter motor but never get start...
