2011 Toyota Tundra Remote Start Bypass
benjf3
Member - Posts: 21
Posted: December 04, 2012 at 8:32 PM / IP Logged
Have a 2011 Toyota Tundra that my friend wants a Remote Start installed. I need a bit of direction as to which bypass to use. I have confirmed with them that the key is a black key with no G stamped into it. However, all the bypass modules I'm finding state the firmware only works for the 80 bit "G" keys. I'm likely installing a Code Alarm (5150 or 5152) with Flashlogic Bypass (iDataLink) or an Astro RS-623 with DB-ALL depending on what he wants to spend. I've checked the instructions and they all say the same - not compatible with anything other than a "G" key. I know he won't want to give up a key and a D2D intall is much easier anyway. Can anyone here confirm what is needed or what they are using? I assume that it has a factory alram at minimum and requires some type of bypass. Thanks in advance for any help and info.
vipercon99
Member - Posts: 8
Posted: December 04, 2012 at 11:23 PM / IP Logged
This is the firmware versions for DB-ALL
Some Toyota 2010 model have a different encryption
types. Please look at your key blade and identify the mark.
A dot “.” means the vehicle must be used with TL1 and can’t work with TL4 firmware.
A “G” means the vehicle is valid for TL4 firmware.
Flashlogic FL-Can is also a good choice.    Keep in mind both of these bypasses will require special updater cables connected to the computer to flash to the correct firmware.
benjf3
Member - Posts: 21
Posted: December 05, 2012 at 6:10 AM / IP Logged
Thanks for the info. I spoke to the person and they didn't confirm the key markings because they only checked the plastic. I'm waiting to hear back. They want a basic start with door lock, so I'll likely be using the less expensive Code and Flashlogic module. I am aware of the need to program the firmware. The dealer I get the bypass modules from sends them pre-programmed, but I have to confirm which firmware for him to load.
benjf3
Member - Posts: 21
Posted: December 07, 2012 at 12:04 AM / IP Logged
Follow up: I confirmed this DOES have the G stamped in it. They didn't look on the shaft. So, this is not a problem with the FL-CAN.
Next question is does anyone know if these vehicles have built in Anti-Grind? The ignition looks to be low current from my initial research and I know the Malibu I got my daughter has a low current ignition with Anti-Grind. It would be helpful information so I know if I need to order a relay kit ahead of time. I alway install anti-grinds in my installs. Thanks again for all the info.
Platinum - Posts: 12,488
Posted: December 07, 2012 at 9:48 AM / IP Logged
No factory anti-grind on Toyota vehicles but you will still need extra relays for the 2nd IGN/ACC for this truck.
benjf3
Member - Posts: 21
Posted: December 07, 2012 at 2:41 PM / IP Logged
The Code 5150/5152 have built in relays for IGN 1, IGN 2, and ACC (even a spare output for a 3rd IGN, 2nd ACC, or 2nd Start) on the main harness. Why would I need additional relays? The only line I want to interrupt is the starter.
Posted: December 07, 2012 at 3:10 PM / IP Logged
Didn't realize that the Code system had extra onboard relays, not familiar with this system. You would still need a relay for the anti grind unless of couirse the Code has one of those as well like the Compustar systems.
benjf3
Member - Posts: 21
Posted: December 07, 2012 at 3:48 PM / IP Logged
Nope, done quite a few Code systems. Nice little units, but no built in Anti-Grind. The high current output plug has (2) 12V in, (1) IGN,(1) IGN2, (1) ACC, 1 Start and (1) programmable (ACC, Start or IGN 3). I haven't done a low current ignition install before. I see where the Tundra has a (2) 7.5 Amp 12V lines to it, but I planned on using the 12V main at the fuse box (Thick Black Wire). I just want to ensure I can connect the main harness wires to the thinner Toyota Ignition wires without issue. One would assme you could use the two 12V wires at the Ignition harness and that the Remote Start would then not be able to output more current than it's taking in. However, could that possibly put undo load on that circuit. I'm completely comfortable installing the unit, but I was seeking advice here to ensure longeity and avoid any known potential issues. Thanks all for the input.
How are you shop guys wiring them up for Ignition Harness and power?
This is a 5051 which will be used with the Flashlogic FLCAN in D2D mode.  (I may use the 5152 which is the same unit, but adds an extra AUX out and has nicer metal transmitters)
http://www.audiovoxproducts.com/code-alarm/remotestart/?sku=CA5051
jsolts
Member - Posts: 49
Posted: December 08, 2012 at 12:04 PM / IP Logged
Don't mean to hijack your thread, but I have a question on this vehicle that isn't worth starting a new thread.
Buddy of mine has the same truck, he took it to a big time shop.
They told him that toyotas will not lock when they are running. And that he needed to get a $300 locking kit.
He already has power locks, so I can't see why he would need another module.
I think he got screwed over here.
Am I right? Or does he need a special kit for toyota's?
Posted: December 08, 2012 at 12:49 PM / IP Logged
Most bypass modules will control the lock/unlock and arm/disarm features for this truck without additional modules or relays.
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
