blade al won't program into my car
traditore
Posted: December 14, 2012 at 12:32 PM / IP Logged
Here's what I have:
Firmware: BLADE-AL(DL)-NI4 (1.6)
Hardware: BLADE-AL (32)
2009 Rogue Std. Key SUV/Crossover 4 Cyl.
CM6200 with latest firmware (7.0)
It looks like my BLADE won't learn or program into my vehicle anymore. Door locks don't work, and neither does remote starting (cranks, but doesn't start).
This all happened after I updated the BLADE and CM6200 firmwares. Before, everything was fine and dandy.
I tried a factory reset on the BLADE and even downgrading my firmware. No luck. The LED never turns on blue when I follow the programming procedure.
Any ideas?
shortcircuit161
Silver - Posts: 556
Posted: December 14, 2012 at 2:00 PM / IP Logged
Even though you stated you tried a factory reset, if the LED does not light during programming it usually means it's already programmed.
You may have to do a factory reset again and then try programming it.
When you attempt remote start, does the blue LED on the BLADE turn on at all?
traditore
Posted: December 14, 2012 at 2:44 PM / IP Logged
I just tried again.
Here's what I did to factory reset the BLADE. Unplugged all harness and took out the BLADE. Plugged in the 6P Power Connector. Inserted the BLADE in the CM6200 while holding the BLADE button until the LED flashed quickly. Released the button and waited for the 2-second solid red LED to come one. Then, put the key in the ignition and turned it to ON (so I did not start the car). Unfortunately, the LED did not do anything.
I attempted to remote start the car. No sign of activity on the LED. Car cranks and eventually stalls.
I'm baffled.
shortcircuit161
Silver - Posts: 556
Posted: December 14, 2012 at 3:32 PM / IP Logged
To program the BLADE, it needs to see ignition active. Have you confirmed your ignition wire connections?
The BLADE firmware is the correct one.
You mentioned the Compustar has v7 of the firmware. Are you able to roll it back and try to use the BLADE again?
Do you have the gray/red wire from the BLADE harness connected to Ground?
Platinum - Posts: 7,827
Posted: December 15, 2012 at 6:28 AM / IP Logged
What Blade AL firmware / revision was loaded and running previously?  Maybe some wiring changes came along with the firmware revision?
If this was installed a while ago it might have the older  Blade AL(DL) NI firmware, which is totally different...
traditore
Posted: December 15, 2012 at 2:15 PM / IP Logged
I've read somewhere that, after the reset, I have to select my install type and validate it. And then I can learn the BLADE to my car.
How do I tell the BLADE or the brain which type I selected? My install type is iDatalink 2way.
I'll follow up to the other suggestions you guys made in a while.
Posted: December 15, 2012 at 2:24 PM / IP Logged
The Installation Mode selection ( D2D or Standard W2W ) pertains only to the regular bypass modules, not the Blade cartridges.
traditore
Posted: December 15, 2012 at 11:23 PM / IP Logged
Am I supposed to relearn the tach after a firmware upgrade?
Posted: December 16, 2012 at 6:12 AM / IP Logged
Wouldn't hurt after the Compustars' firmware upgrade.  I would even use the OP-500 to verify all the options are still set as needed.  However, if the Blade will not program to the vehicle, it probably won't be able to produce and supply a Tach output signal...
traditore
Posted: January 04, 2013 at 10:41 PM / IP Logged
It was a firmware issue. I managed to track down my old documentation and I had firmware NI2 originally. The wiring has changed in firmware NI4, which was the new version I updated to.
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
