rs on 2006 honda odyssey
laziebun
Member - Posts: 39
Posted: December 20, 2012 at 8:11 PM / IP Logged
Can anyone tell me where the rear defogger wire is at?
Also in reference to the Xpress XK09, if i D2D the unit to the viper 5904, do i need to do anything else for the power side door to work?
91stt
Silver - Posts: 564
Posted: December 20, 2012 at 10:25 PM / IP Logged
Rear Defrost BLACK / YELLOW (+) UNDER HOOD FUSE/RELAY BOX
Note:THIS VEHICLE USES DATA TO CARRY THE REAR DEFROST SIGNAL FROM THE A/C CONTROL UNIT TO THE UNDER HOOD FUSE/RELAY BOX, MUST USE RELAY AND FUSE AT 30 AMPS
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
laziebun
Member - Posts: 39
Posted: December 21, 2012 at 7:35 AM / IP Logged
could someone explain "uses data...." part to me?
91stt
Silver - Posts: 564
Posted: December 21, 2012 at 9:27 AM / IP Logged
data means that there is no analog way of controlling that particular feature, such as, supplying +12vdc, ground, or the use of resistors to +12vdc or ground, etc. I looked at the popular interfaces and none seem to be able to active the rear defrost feature. The only analog method requires you to pick the wire at the fuse box in the engine compartment.
I do not install DEI products but if the 5904 have auxiliary 1 & 2 channels, it should work. The 5904 may refer to them as different numbers depending on convention they are using, you will need to test the function to determine the proper channel.
