viper 5904 range 1 mile? not quite
rbimdxe
Member - Posts: 10
Posted: December 20, 2012 at 11:26 PM / IP Logged
Hi there
I've recently put in a Viper 5904 due to the benefit of one mile range.. And the paging functions as I like to know if anything happens to the car.
Today I thought I'd do some testing whilst out to lunch but was told I was out of range...
Strange, because I was 250m from the car, with one building between us (both outside in open air). 250m is less than a quarter-mile, and pretty close to 1/8 mile...
Walking back to the car I again was testing range and finally got a response at approximately 160m (or roughly 0.1 mile)..
The antenna is mounted high on the windscreen and the remote is fully charged.
Does anyone have any suggestions how to improve range or is the advertised 1mile range really meant to be 0.1mile range??
Alex :)
Posted: December 21, 2012 at 3:19 AM / IP Logged
If I give you the whole story of why you haven't got the range, you'd be reading for the next six months but simply.
1 mile is a MAXIMUM under conditions of flat ground, no buildings* or natural objects, hills trees etc.
Antenna quality and placement.
Transmitter battery condition.
It's a bit like European (the US is more stringent) market mpg economy (fuel consumption) lists.
NEVER achievable in the real world.
The whole thing is a mixture of science and installer experience/ingenuity.
Ever tried to make a cell call from inside a buildings lifts (elevators)?
*Steel framed concrete building with tinted glass? Forget it.
lurch228
Silver - Posts: 1,338
Posted: December 21, 2012 at 3:22 AM / IP Logged
1 mile range is a maxium range with true line of site, not with a building between you and the system as every wall will effectively cut range by half. And brick or block walls will be more so degrading to range. Also if the windsheild has a foil layer to it will also cut range.
Posted: December 21, 2012 at 4:19 AM / IP Logged
Some Euro vehicles also had a metal film in the windscreen (wind shield) I remember in the cell phone car kit days that glass mount antennae were useless, also GPS.
rbimdxe
Member - Posts: 10
Posted: December 21, 2012 at 4:49 AM / IP Logged
Thanks for the replies.
Yes I understand it is a theoretical maximum however I have read on here someone's account of having a range of 3-5 thousand feet in a city area... With one of the older models..
I don't believe that even with true line of sight on flat ground (when I did get reception) that one-tenth of the advertised range is acceptable...
Obviously it would be a case of "the company is too big to try and take to court so I'll have to shut up and deal with it" but come on. I'm a bit disappointed..
No, no foil layering on the windscreen. Australian delivered Jap car.
soundnsecurity
Gold - Posts: 2,720
Posted: December 21, 2012 at 10:48 AM / IP Logged
what car do you have exactly? and are your windows tinted at all? lots and lots and lots of things could be killing your range, buildings, atmospheric conditions, obstacles such as buildings, interference from power lines and other high power utilities. the 1 mile range is maximum for the absolute ideal conditions. the 1 mile range is a gimmick on every alarm that claims to have it.
Platinum - Posts: 7,828
Posted: December 21, 2012 at 11:01 AM / IP Logged
Times 2 with all the above.  Range "claims" are the maximum possible under very ideal conditions.
You could try moving the antenna to different locations to see if you can get better results.
Of course, the effect of Earths magnetic flux lines where North is South, Winter is Summer and everyone drives
on the wrong side of the road might have something to do with it...   viper 5904 range 1 mile? not quite -- posted image.
lucasoil4u
Copper - Posts: 317
Posted: December 21, 2012 at 11:28 AM / IP Logged
Viper always over rates there systems. I install alot of excalibur. I have gone 1 mile from the truck and hit the button it took a minute but I got a confirmation. The antenna shouldnt be behind the dot matrix that will hurt some range. I truely doubt you will ever see 1 mile range in the cities with that. Power Lines kill the range. Cell phone towers kill the range. If you want a true one mile of range look at a different unit.
Posted: December 21, 2012 at 11:29 AM / IP Logged
Visiting Australia is on my Bucket List.  Hopefully someday I'll get there ( and rent a Holden Ute SS and try to learn to drive all over again ).
I wonder if anyone has tried extending the Antenna harness ( with a little cut and splice surgery ) and mounting the antenna at the rear window?
soundnsecurity
Gold - Posts: 2,720
Posted: December 21, 2012 at 7:23 PM / IP Logged
i had the idea once to put the antenna in one of those magnetic waterproof key holders and mount it under the plastic panel at the bottom of the windshield. this way the antenna would be outside the cabin and probably get better range
