2001 nissan pathfinder
bat9905
Copper - Posts: 131
Posted: December 31, 2012 at 9:08 PM / IP Logged
2001 nissan pathfinder door ajar light on which won't allow me to arm xro9100 and protect door circuits . My factory alarm also doesn't protect doors . I've tested switches fine. Rear wires for door and hatch are supposed to go to ground . When all doors are closed no voltage present . Please help I'm starting to think its a faulty secu
bat9905
lurch228
Silver - Posts: 1,338
Posted: January 01, 2013 at 4:08 AM / IP Logged
Try a reset by pulling the neg battery terminal for al least 10 min. or more to see if the security will reset.
bat9905
Copper - Posts: 131
Posted: January 01, 2013 at 9:26 PM / IP Logged
I tried that and still nothing. I was running out of ideas so i took it to the dealer regrettingly. They charged me and told me it was the rear hatch. Since then i metered the the hatch and noticed it goes to ground when opened so i disagree. it never recieves 5 volts when door is any position.
bat9905
Platinum - Posts: 13,725
Posted: January 01, 2013 at 9:54 PM / IP Logged
     LF Latch GREEN/ RED (-) LEFT OF STEERING COLUMN AT SECU MODULE
     RF Latch YELLOW (-) LEFT OF STEERING COLUMN AT SECU MODULE
     LR Latch RED / BLUE (-) LEFT OF STEERING COLUMN AT SECU MODULE
     RR Latch RED / BLUE (-) LEFT OF STEERING COLUMN AT SECU MODULE
     Trunk Trigger BLUE/WHITE (-) LEFT OF STEERING COLUMN AT SECU MODULE
bat9905
Copper - Posts: 131
Posted: January 01, 2013 at 10:22 PM / IP Logged
The rear doors and hatch are red with black. Everything worked fine until my rear hatch wasnt shut all the way and for 2 hours my alarms went off. since then there is no voltage to red with black wires opened or closed. Ive checked continuity all back to secu and its fine
bat9905
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
