Help, Viper C-60 alarm hook up
kevmor99
Posted: May 10, 2003 at 2:52 PM / IP Logged
I just got a used viper c-60 alarm and I wanted to test it before installing it.  I hooked up ground to the constant ground and 12v to constant power.  As soon as I do this, the siren wire gets power and I can hear a relay click on and off (I assume the parking lights flashing).  The wire for ground when armed doesn't have ground at any time.  When I use different buttons on the two remotes I have neither effect it.  After about 20-30 seconds the alarm cycles off and I can make it go off again by putting ground to one of the sensor wires.  I tried the valet switch but it didn't seem to change anything.  If this alarm was out of a vehicle for a while, would it have lost it's memory for the remotes to work and do I have to reprogram them?  Putting power to the ignition on wire only makes a relay come on/off and doesn't turn off the alarm either.  Am I doing something wrong? It just doesn't seem to be working quite right.  It was fine when taken out of the vehicle.
draasch
Gold - Posts: 2,172
Posted: May 10, 2003 at 7:41 PM / IP Logged
you can try dei.com and see if u can find the wiring info for that alarm
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
jaxman
Copper - Posts: 185
Posted: May 13, 2003 at 3:24 PM / IP Logged
Must be an old system as I never heard about a Viper C-60.
If the system was out for 10 years if the reotes were from that system they should still work.
