emissions test failed cause of remtoe sta
jpadj22
Copper - Posts: 100
Posted: March 22, 2013 at 10:31 AM / IP Logged
I did a r/s awhile ago on my friends nissan 07 sentra. They had the emissions test and they told him it failed because of the remote start. I used an idatalink ads bypass module and i did have to tap in to the obd plug for the CAN  H and CAN L. The only thing I can think of is to cut the wires and try and pass the test, then splice them back once the test is done.Has anyone been threw this before? Does anyone know if my solution will work? Whats the reason for it failing? Any suggestions would be great thanks.
No better feeling then getting a remote start to work right!
Posted: March 22, 2013 at 12:52 PM / IP Logged
Or get an inductive pick-up for the Hi-Lo.
jpadj22
Copper - Posts: 100
Posted: March 22, 2013 at 1:56 PM / IP Logged
Thanks for the reply. Im not familiar with inductive pick up for hi-lo. How is that wierd up?
Posted: March 22, 2013 at 2:04 PM / IP Logged
Not "wierd" at all, quite straightforward. we use them over here with trackers exactly to avoid your problem.
Google Sailes-Marketing or "inductive OBD CAN pick-up".
jpadj22
Copper - Posts: 100
Posted: March 22, 2013 at 2:44 PM / IP Logged
Ok thanks ill do some research. Just in case this happens to some one eles, taking those wires off the obd will work to pass the emissions test. I already soldered them back together everything is working fine.
Posted: March 22, 2013 at 2:50 PM / IP Logged
You would probably have got away with pulling the idatalink module's fuse.
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
