viper 5904, keeps trying to start car
tomt614
Member - Posts: 16
Posted: May 12, 2013 at 11:28 AM / IP Logged
Hey folks,
This is my first post and I've been doing a lot of searching and I cannot figure out what is wrong. First off, I installed a Viper 5904 to my 2009 Honda Accord LX. After everything was wired, I programmed my pkall, paired my remote, set my transmission mode. This is where the fun begins... I decided to try out the remote start, pushed the button, heard a cheerful acceptance by the remote, heard the engine crank... Cars panic went off, so the only way to stop the panicking was to disconnect the power wire to the alarm, and yes, I tried the battery, and no, it didn't shut the car up. So now, every time I connect the alarm to test again, it'll automatically crank the car, over, and over, and over, as well as the panic. Should I just have the pkall reset and the firmware reloaded?
Posted: May 12, 2013 at 1:03 PM / IP Logged
"Car's panic went off" are you talking about the factory alarm or the 5904?
tomt614
Member - Posts: 16
Posted: May 12, 2013 at 3:46 PM / IP Logged
Yeah, but my model doesn't have a stock alarm. It's just equipped with the transponder and engine cutoff. I can manually unlock the car by just reaching through the window while its "armed." Thanks for the reply!
tomt614
Member - Posts: 16
Factory.
tomt614
Member - Posts: 16
Posted: May 12, 2013 at 3:49 PM / IP Logged
I've also unhooked my sirens and plugged everything back in to reset the brain and remote, but I get the same results. I used the reset procedure from the 5904 manual.
Posted: May 12, 2013 at 4:10 PM / IP Logged
Use the Excell file as shown on the top of this forum and list your connections to the vehicle wires, maybe we can spot something.
tomt614
Member - Posts: 16
Posted: May 12, 2013 at 5:01 PM / IP Logged
Ok, I'll post my connections later tonight. My wife would kill me for spending more time troubleshooting this alarm on Mother's Day. Lol
tomt614
Member - Posts: 16
Posted: May 13, 2013 at 2:32 PM / IP Logged
viper 5904, keeps trying to start car -- posted image.viper 5904, keeps trying to start car -- posted image.
Here's what I have so far. Sorry for the pics, doing everything from my phone.
Posted: May 13, 2013 at 5:23 PM / IP Logged
3 things stand out immediately.
1) By-pass? Isn't one needed for this vehicle. 556UW
2) Key sense use the H2/9 dark blue for both by-pass and keysense, white at ignition switch plug and diode separate.
3) H3/7 Pink/white to red at ignition loom program it as ACC 2.
Next question does the factory alarm kick off or the 5904 because you also need to disable the factory alarm.
Disarm brown (key unlock) and white (unlock detection).
Diode separate, double pulse NEG (-) power window master switch, gray 37 pin plug, pins 29 and 31.
tomt614
Member - Posts: 16
Posted: May 13, 2013 at 5:34 PM / IP Logged
Give me a bit and I'll post up my connections for the bypass.
Page of 3
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
