avital 4300 avistart horn connection
ddd64
Posted: May 22, 2013 at 1:28 PM / IP Logged
I have a 1996 chevy blazer with avital 4300 avistart. I am trying to connect the horn. Is this possible with this system? If so how would I do this.
Donnie
Platinum - Posts: 7,828
Posted: May 22, 2013 at 1:49 PM / IP Logged
The Avital 4300 Install Guide suggests that the Brown wire at H4/2 is the (-) 200mA Horn output. Should be able to directly connect to the Blazers horn wire.
Horn Trigger       Black (-)  @ steering column
ddd64
Posted: May 22, 2013 at 2:03 PM / IP Logged
Ok I am a little confused. So where would I plug the h4/1/2 connector to the module. According to the wiring diagram it shows the h4 being plugged in but on the module it self there is no place to plug it in.
Donnie
cmk0808ny
Copper - Posts: 203
Posted: May 22, 2013 at 2:23 PM / IP Logged
The later 4300 models had the horn output. The earlier models did not. You may have an earlier version. Only siren output for the earlier version.
ddd64
Posted: May 22, 2013 at 2:29 PM / IP Logged
Ok now I understand. It appears I have earlier version. Thank you very much
Donnie
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
