96 camaro viper keyless entry
morodder
Posted: August 15, 2013 at 6:07 PM / IP Logged
I am trying to install a keyless entry viper 211. I just like to learn and do it myself. My question is. The lock #87 normally closed, lock #30 common output, lock normally open input, unlock #30 common output, unlock #87 normally open output. What are these? I know have lock RED / black, unlock tan and gray/black. Door trigger gray/black and BLACK/ white. I really thank you for the help.
chev104275
Gold - Posts: 1,436
Posted: August 16, 2013 at 7:52 AM / IP Logged
The numbers 87 and 30 refer to the systems internal relays. 87 being the input. whether your locks are positive or negative trigger you would connect that wire accordingly. 30 being the output to the locks
morodder
Posted: August 16, 2013 at 2:36 PM / IP Logged
So just to make sure. Common is for the neg locks for it to lock and normally closed is if it needs positive that needs to close. Thanks for the help...
morodder
Posted: August 16, 2013 at 4:01 PM / IP Logged
I could really use some help. I am wiring a.96 camaro. With viper 211 keyless entry.
Lock 30 common output
Lock 87 normally closed
Lock 87 normally open ( input)
Unlock 30 common (output)
Unlock 87 normally open (input)
Unlock normally open ( input)
Unlock 87a normally closed.
If you could tell me how to wire this you would be my hero....thanks brian
the12volt
Administrator - Posts: 3,959
Posted: August 16, 2013 at 5:45 PM / IP Logged
The numbers refer to the terminals of an SPDT relay. Your vehicle has 3 wire negative switch door locks. See the references below.
https://www.the12volt.com/doorlocks/page3.asp#3wp
https://www.the12volt.com/relays/relays.asp
https://www.the12volt.com/installbay/alarmdetail/487.html
96 camaro viper keyless entry -- posted image. the12volt • Support the12volt.com
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
