1995 avalon remote start trunk release
gileadb
Member - Posts: 7
Posted: November 24, 2013 at 6:01 PM / IP Logged
Hi,
I am going to be attempting to install an Avital 4103 in a 1995 Toyota Avalon. After looking over wiring diagrams, and the install guide for the avital unit, I feel confident in wiring everything but the trunk release. My question is do I need a relay to connect the -200ma output from the avital unit to the WHITE/ blue - trunk release wire? Or do I connect it to the - RED / white trunk pin wire? If I need a relay could anyone point me in the right direction as to which type of relay?
The wiring diagram I am going off of is this one:
https://www.the12volt.com/installbay/alarmdetail/2030.html
Sorry if these are obvious questions and thanks for your help.
triniforever
Copper - Posts: 323
Posted: November 24, 2013 at 6:08 PM / IP Logged
For most negative trigger trunk release the output from the remote start should be enough to trigger the trunk release , it's easy to test with a test light , one end go the test light should be attached to ground and the other end can momentarily be touched to the trunk release wire ,if the trunk pops you are good to go.
triniforever
gileadb
Member - Posts: 7
Posted: November 24, 2013 at 6:20 PM / IP Logged
Thank you, is there anyway to test it with a multimeter?
buddholly
Copper - Posts: 244
Posted: November 24, 2013 at 6:38 PM / IP Logged
put one probe to ground, one to the (-) trunk release wire, set meter to dc volts, should should about 12 volts at rest and show 0 volts while button is pressed.
gileadb
Member - Posts: 7
Posted: November 24, 2013 at 6:49 PM / IP Logged
Thank you, so if it moves to 0 when the button is pressed, I am safe to splice directly into it with the -200ma output?
buddholly
Copper - Posts: 244
Posted: November 24, 2013 at 9:55 PM / IP Logged
Yep. No relay is needed.
gileadb
Member - Posts: 7
Posted: December 01, 2013 at 10:33 AM / IP Logged
Thanks for the help. Sorry for the late reply, I only got a chance to test it today. It starts at 6 volts and moves to 0. Am I still safe with no relay or should I use a relay? Thanks
