Posted: February 03, 2014 at 8:30 PM / IP Logged
Posted: February 04, 2014 at 1:12 AM / IP Logged
Posted: February 04, 2014 at 2:59 PM / IP Logged
Posted: February 05, 2014 at 4:43 AM / IP Logged
Posted: February 06, 2014 at 9:37 PM / IP Logged
Posted: February 10, 2014 at 10:46 PM / IP Logged
Posted: February 11, 2014 at 10:21 AM / IP Logged
Posted: February 11, 2014 at 2:11 PM / IP Logged
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
. I can't program the fob remote since the valet switch is not functional, I know I know stupid move. Either way I need to problem solve this so I can get this alarm working.
Any help would be greatly appreciated
Here is a list of how I wired my alarm harness.
Wire Desc. / Wire Color on alarm harness / (Polarity) / Location of wire(color of wire from car)
-Chan2 output / (RED / white) / (-) / to trunk release
-12 volt constant power / RED / (+) / ignition harness(white)
-Siren output / brown / (+) / to (+) of siren (red)
-Ignition input/ yellow / (+) / ignition harness(input to 86 on relay, output to white ignition harness) See diagram *
-Chassis ground / black / (-) / grounded to chassis
-Positive door trigger / Violet / (+) / NOT USED
-Instant trigger input / Blue / (-) / Wired to hood pin, engine hood pin, and negative polarity on trunk light
-Negative door trigger / Green / (-) / passenger kick panel (RED / white wire that reads -12v when door is open)
-Dome light supervision / (BLACK/ white) / (-) / to (-) door trigger input on driver kick(RED / white) See diagram **
-Chan 3 output / (WHITE/ blue) / (-) / NOT USED
-Light Flash output / White / (+) / Driver kick panel taillight harness(green that shows 12v when parking lights on)
-Ground when armed / Orange / (-) / to starter kill relay terminal 85, see diagram *
-Power Lock / green / (-) / passenger kick panel(black)
-Power Unlock / blue / (-) / passenger kick panel(BLACK / YELLOW)
Diagrams
* Relay for starter kill include terminals 85, 86, 30, 87, 87a
- 87: not used
- 85: Ground when armed wire(orange from main alarm harness)
- 30: Black from relay to Ignition 1(BLACK / YELLOW) on coil side[igntion 1 cut on harness]
- 87a: Green from relay to ignition 1(BLACK / YELLOW) on key side[ignition 1 cut on harness]
- 86: Yellow from relay to 12v constant(white on ignition harness)
**Relay for dome light supervision include terminals 85, 86, 30, 87, 87a
- 87: From relay to chassis ground
- 85: to fused 12v constant
- 30: Door trigger on driver kick panel(RED / white wire)
- 87a: Not used
- 86: BLACK/ white from alarm main harness
