compustar cs 800/2007 mercury montego
co_ne_dub
Copper - Posts: 80
Posted: February 20, 2014 at 8:00 PM / IP Logged
Let me preface this by saying I have been installing Python RS's for years. Decided to jump over to Compustar and trying out their new CS800. The issue I am having is on this montego it will start one time and then attempt to start the next. With the Pythons I would always hardwire all the connections(power,GWI, ground, so on) I use mainly iDatalink bypasses.
On this particular vehicle I tried the 2 way datalink protocol. Could that be causing my issue?
Maybe the bypass and the RS are dropping communication. Should I try the 1 way data?
Platinum - Posts: 7,827
Posted: February 20, 2014 at 8:47 PM / IP Logged
I haven't used / seen any CS800's yet but the last I heard the CS600 brain used with the CS600 and CS700 units is only one-way D2D compatible.  Don't know what they are using on the CS800 systems.
enice
Silver - Posts: 857
Posted: February 20, 2014 at 11:30 PM / IP Logged
If I am not mistaken the CS800 should be 2 way D2D Compatible. Also, you must make sure the system is set for tach. By default, the system is on voltage mode. Set 2-4 to 2 and program tach.
Eric
Audiomaxx
528 East Fordham Road
Bronx NY 10458
Compustar Top Gun Dealer Award 2012-2013
co_ne_dub
Copper - Posts: 80
Posted: February 21, 2014 at 9:28 PM / IP Logged
Thanks! We will get it back Monday morning to fix the issue
blanx218
Silver - Posts: 654
Posted: February 21, 2014 at 10:10 PM / IP Logged
The only issue I've had with 2way d2d on 600 brains is anything with a red line on the idatalink diagram. i.e. tach, brake, etc. Doesn't sound like a d2d issue. Does the security light flash when it fails to start?
enice
Silver - Posts: 857
Posted: February 23, 2014 at 11:00 PM / IP Logged
I just confirmed last night that the CS800 is indeed 2-way compatible.
blanx218... when you do see the red lines it means that its only compatible with "2-way" hence why it didn't work on the 600 brain. The 600S and 700S are "1-way' only.
Eric
Audiomaxx
Bronx NY 10458
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
